Spec Boxsters For info sharing on this exciting new class
Lightest wheels
Old 11-12-2016, 01:32 PM
hf1
hf1's Avatar
Received 1,639 Likes on 1,122 Posts
Default Lightest wheels
So which 8.5 wheels are the lightest? Has anyone done a weight comparison of all SPB legal wheels? PM me if it's a big secret. Or don't.
EDIT: How much $ do these 8.5s go for these days?
Old 11-12-2016, 03:47 PM
hf1
hf1's Avatar
Is there a list of allowed SPB wheels (Porsche part numbers) available? Would 987 17" wheels fit/work and if so are they allowed?
Old 11-12-2016, 04:01 PM
Gary R.
Gary R.'s Avatar
2016 PCA Rulebook;
"I. Any factory cast aluminum rims intended for a Boxster and matching the original offset are allowed; front wheels must
be at least 18.5 lbs. and rear wheels at least 20 lbs. Rear wheels must be 17 x 8.5 inch, 48‐50 mm offset. Front wheels
may be either 17 x 7 inch, 55 mm offset, or the same size and offset as the rear wheels (17 x 8.5 inch, 48‐50 mm offset)"
Old 11-12-2016, 06:11 PM
hf1
hf1's Avatar
Originally Posted by Gary R.
2016 PCA Rulebook;
Thx Gary!
Old 11-12-2016, 09:50 PM
hf1
hf1's Avatar
Any opinions/experience on using a square 7x17 set for rains? Narrower contact patch is usually better for rain and/or standing water.
Old 11-12-2016, 11:53 PM
Gary R.
Gary R.'s Avatar
You are correct, and if I was running in the rain I would consider 4 7" Rain tires as the 7" wheels are cheap and readily available.
Old 11-13-2016, 12:01 AM
Gary R.
Gary R.'s Avatar
Thx Gary!
I should add I would love to find a set of 8.5" 20 lb wheels! The lightest i've seen listed is 21 lbs..
Old 11-13-2016, 09:07 AM
toddlamb
Basic Site Sponsor
toddlamb's Avatar
Some useful info:
https://rennlist.com/forums/spec-box...l#post12849144
Todd Lamb
Atlanta Speedwerks
www.ATLspeedwerks.com
Porsche repairs, servicing, and upgrades / Certified IMS installer / PDK repair experts
Over 150 PDK's repaired and counting:
https://youtu.be/m54P_zisEcI
Old 11-13-2016, 09:57 AM
hf1
hf1's Avatar
Originally Posted by toddlamb
Thx Todd, that was useful.
Old 11-20-2016, 03:17 PM
jdistefa
jdistefa's Avatar
Brad Roberts had proposed a 7 square setup for rains a couple years ago but I don't think it got any traction (haha) with rules committee.
Old 11-20-2016, 03:22 PM
hf1
hf1's Avatar
Is it expressly prohibited by the rules? If yes, then on what basis is the 4x8.5 setup allowed?
Old 11-20-2016, 11:16 PM
jdistefa
jdistefa's Avatar
^ Rules are clear. You can run 8.5" square or 8.5/7" stagger. 7" square not allowed.
Old 11-21-2016, 12:19 AM
Gary R.
Gary R.'s Avatar
I don't have a dog in the fight as I won't run in the rain, but that's a stupid rule that goes against both the frugality of the class but also against everything I have read about rain tire sizing..
Old 11-21-2016, 01:43 AM
jdistefa
jdistefa's Avatar
^ I don't disagree but those are the rules as currently conceived.
Old 08-28-2017, 10:33 AM
PGas32
PGas32's Avatar
Bumping this up as it's still not clear on what the different wheel designs weigh, or if it makes a difference. I've acquired enough wheels to do a square setup, a staggered setup, and a rain setup...want to use the heaviest wheels for the rains. I have Sport Classics, Carrera twists, and Boxster S twists. This site lists the Boxster S twists at 10.4kg, but is missing weights for the other two designs in 8.5". Anyone have that info??
Quick Reply: Lightest wheels
