Spec Boxsters For info sharing on this exciting new class
Tranny temp sender location
Old 05-12-2014, 12:41 PM
flatsixforme
flatsixforme's Avatar
Default Tranny temp sender location
For those of you who have installed a temp gauge where have you put the sender? If anyone has drilled the case and has a picture of the location that would be great.
Old 05-13-2014, 10:04 AM
mcipseric
mcipseric's Avatar
If you are running a pump and cooler, then...
Place the sensor in the external filter before the cooler.
Old 05-13-2014, 12:35 PM
flatsixforme
Hey Eric - not running a pump and cooler yet but will in the future. One idea that a mechanic buddy of mine was thinking of was to use the drain plug hole and find a hex head bolt of the same size to drill and tap for the temp sender. This could work but I'm not sure is ideal because you would lose the magnet function of the drain plug. When a pump and cooler are installed you can fun a filter to take that place of course. I'm sure someone has tapped the case, just curious where.
Quick Reply: Tranny temp sender location
