Lindsey Instant RWHP Kit - Dyno
Old 02-20-2017, 03:32 PM
Flea3
Flea3's Avatar
Default Lindsey Instant RWHP Kit - Dyno
I was off today, so I had this done. I wanted everyone considering this kit to know what it does. I noticed a lot of dyno's for the bigger kits but none for the smaller ones. I feel like this was a pretty good result for the base kit.
1988 944 Turbo - Not and S
60 degrees
Lindsey Instant RWHP Kit only
I'm thinking about a test pipe as well, but haven't decided. I'll post that in a few weeks if I do it. I am not going "big" with this particular car but a few minor reversible mods should be okay.
Old 02-20-2017, 05:51 PM
Paulyy
Professional Hoon
Paulyy's Avatar
What was in the kit?
Old 02-20-2017, 07:23 PM
bradthebold
bradthebold's Avatar
Looks like chips, FPR, boost enhancer, and WG shims.
Old 02-20-2017, 08:55 PM
Paulyy
Professional Hoon
Paulyy's Avatar
LOL yeah, that's what i said when i replaced a few things.
Sounds right.
Decent gains for spending next to nothing.
Old 02-20-2017, 09:01 PM
Bmuldoon
Bmuldoon's Avatar
Flea, this was with a stock exhaust w/cat?
I recently converted to a catless 3" exhaust and have been considering the RWHP kit.
Old 02-26-2017, 12:23 AM
Flea3
Flea3's Avatar
Yes, the exhaust is stock and the car has its cat. It has no other modifications, other then the kit.
Old 02-26-2017, 09:49 AM
michael7810
michael7810's Avatar
Anyone dyno a stock 951 or know the stock RWHP for comparison? This looks like a nice bump in power for minimum effort and cost. Thanks
Old 02-26-2017, 05:08 PM
raleighBahn
raleighBahn's Avatar
It's an inexpensive horsepower bump, but one that should be watched with a wideband and boost gauge from day one. If you find the horsepower gain to be dramatic, you might be building too much boost and be on short time.
I had a boost enhancer with a-tune, and found the boost enhancer to have too much boost out of the box. I backed mine down to hit 13 psi or so, and the a-tune did a good job keeping afr safe. You don't want more than 15 psi on pump gas, and the stock head gasket rated for 14.7 I believe.
The main thing a boost enhancer does is make you realize what a good enhancement a dual port wastegate, boost controller, and gauges will be.
Old 02-26-2017, 05:54 PM
333pg333
333pg333's Avatar
Would have been really handy had you done a base run before installing this kit.
Old 02-28-2017, 10:51 PM
Ak951
Ak951's Avatar
I've been dailying 18-19psi the past year with zero issues, few of those months on a bigger turbo and e85. Stock blows out at 24 with stock hardware iirc.
Old 02-28-2017, 10:55 PM
Ak951
Ak951's Avatar
I dyno'd 260whp 310wtq with chips, mbc at 18psi, wastegate shims, and 3" exhaust catless with stock downpipe.
stock is around 195whp 220wtq iirc
Old 03-01-2017, 05:52 PM
V2Rocket
Rainman
V2Rocket's Avatar
the numbers on the chart - are those measured at the wheels or "corrected to crank"?
if wheels, chips + fuel pressure + wg shim for ~60 crank hp is super cheap...
Old 03-01-2017, 08:12 PM
raleighBahn
Sorry, by pump I meant 93, not e85.
Quick Reply: Lindsey Instant RWHP Kit - Dyno
