996 Forum 1999-2005
First trackday on the 996. Tips and/or advice?
Old 01-16-2017, 03:43 PM
stan23
stan23's Avatar
Default First trackday on the 996. Tips and/or advice?
Excited to sign up for my first car trackday at Fontana!
Let me preface by saying, i've done over 10 years of motorcycle trackdays, and 3 years of motorcycle road racing--so i'm familiar with the track routine. I had done a bunch of SCCA Solo AutoX, 20 years ago, but you can say i'm still a newbie car driver -- even @ 40 years old!
I have a fully serviced and ready to go '01 C4, with brand new tires (S04s) and stock M030 suspension. The car has 57K on it.
I am currently running street pressures of 36f/42r, but I guess i'll adjust accordingly when i'm at the track. Not sure of ambient track temps at this point--never been to Fontana.
When I had the tires installed, I got a 'street' alignment (which really means 1.5 degrees of negative camber instead of -2. Toe is set to 0 f/r.
I have newish OEM brake pads, and coolant tank in perfect shape, as well as zero leaks of any kind, not even any signs of wetness from the RMS.
I will install my tow hook on the front bumper, and going through the self tech list, I don't see anything that sticks out on my car, that I need to address.
While I have the ability to tow my car to the track, I decided to drive it there and back (about 400-miles each way) I'm heading the day before the event, so I should be rested.
Is there anything else I should double/triple check on my car before heading out?
Old 01-16-2017, 04:07 PM
dkraige
dkraige's Avatar
Double check that all your wheel bolts are tight, fluids are topped off, and before you go out on track check that the trunk is shut tightly. I've seen people do dumb stuff like empty their trunk and/or check brake fluid under the trunk lid, then forget to shut it securely, and on the first lap at speed it flies up and hits the windshield...not good!
Between sessions check all your fluid levels and adjust your tire pressures as needed. Your 36/42 pressures are a safe starting point. Keep an eye on your brake pads too; OEM pads can disappear rapidly at track days, so just glance at them after every session to make sure you aren't running out of brakes.
Each session I'd focus more on finding a good, consistent line, and getting comfortable with the car's handling, rather than going for a lap time. In any fast turns, work your speed up gradually so that you don't get to a place where you're tempted to lift mid-corner; make sure you can accelerate through the turn to keep the car planted until you're more comfortable. The only way you're going to get into real trouble in this car is if you don't leave enough braking distance for a slow turn, or lift abruptly in a fast turn. Both can be easily avoided by planning ahead and only adding speed gradually.
Remember that you are driving your car back home! If something looks/feels/sounds/smells funny, stop and check it out before it becomes a real problem. If you aren't feeling comfortable and safe, stop and take a breath. Your instructor should help you stay within the limits of the car and yourself. I'm sure you already know all this from the motorcycle track work!
HAVE FUN! Track days can be a huge blast if everything goes your way and you have the right attitude, or they can quickly become a nightmare if you have problems or choose to focus on anything negative.
I wish it was warm enough here to go to a track! Couple more months of waiting for me...
Old 01-16-2017, 04:18 PM
Sneaky Pete
Sneaky Pete's Avatar
Don't listen to Slakker......
Old 01-16-2017, 04:22 PM
stan23
stan23's Avatar
Wow! Very good tips! Really appreciate it! It was recommend that I bring a backup set of brake pads, is that something I should do? I have done a bunch of brakes on cars and bikes, but never with the brake wear sensor -- are those single use items, or can I put new pads on and keep the sensor?
I've never been the guy always wrenching in the pits - I like to be well prepared so I can just enjoy the day.
That said, i'll bring my jack, some stands, and tools for wheel removal (just in case)
Last thing, PSM on or off? Again, I consider myself a novice performance driver, and I kinda like having the aid on - for those oversteer pucker moments, but I don't want it to be super invasive.
Old 01-16-2017, 04:42 PM
TonyTwoBags
TonyTwoBags's Avatar
clutch in if you spin
Old 01-16-2017, 04:49 PM
thebutterson
thebutterson's Avatar
When did you last change the brake fluid? You should go out with fresh fluid, something high temp if you can.
Old 01-16-2017, 04:56 PM
stan23
stan23's Avatar
The car is newish to me, but yeah - I should do a change just to be safe. I still have a sealed can of ATE superblue (my favorite) but it's several years old. I may just go get some RBF600.
I assume the Porsche bleed process is like any other car, start with driver, and work my way 'round? I have a mityvac to help things get going.
[EDIT] nevermind, looks like with PSM, I need to find a PST2 to bleed. May just have a shop do this for me.
Old 01-16-2017, 05:03 PM
SWK6Cup
SWK6Cup's Avatar
Even though you are familiar with track protocol, pack a smile, listen to your instructor, make sure you drink fluids and a bit of sugar (helps the brain), you might be more mentally exhausted than you realize. Also, wiggle your fingers on a straight-a-way, (helps to get rid of death grip) and BREATHE, there is a lot going on......enjoy! It is highly addictive and you should meet some great people!
Old 01-16-2017, 05:04 PM
dkraige
dkraige's Avatar
Is it a 1-day event or 2-day weekend? If only 1 day, you'll be fine on pads since you say they're pretty new. If it's a 2-day event, you'll probably still be fine, but a backup set wouldn't hurt. I don't know how demanding Fontana is on brakes, but killing a set of OE pads in 2 days is not unheard of. But honestly I'd just sort of take stock of things after each session, and if it seems like you are consuming all your pads, maybe take a step back and think about whether you can back off on your braking, and make sure you don't have any dragging calipers or anything. If you eat a whole set of brakes your first event, you're probably overdriving the car.
The wear sensors can be transferred to new pads IF you replace the pads before they get so thin that the sensors are destroyed It also won't hurt anything to drive without wear sensors; I've deleted them from my car since I check pads extremely frequently anyway. You have to short the wires out though, to avoid having a warning light on all the time. Something to do on leisure time; not a great track-side mod to be performing.
Leave PSM on for at least your first couple sessions. As you build speed, if you see that light flicker and feel it cutting power, you know that's a spot on the track where, at least in the car's mind, you are overcooking it. I've found it to be pretty non-invasive on most tracks, but there are usually one or two corners where it flickers, and might cut power on exit and slow me down. It lets you know that once you turn the nannies off, that's a spot you need to be on your game to avoid wheelspin or too much slip angle. It's actually a pretty valuable coaching tool just to give you a little heads-up, like "hey, **** might get real here if you have to make a mid-corner adjustment or something". Remember it's all fun and games when you're on the perfect line, but if you're bumping up against PSM and then you have to alter your line because of traffic, debris, oil, whatever, suddenly you're on a new line and your margin of safety could be gone. Just like I said burned up brakes indicate overdriving, if you're constantly tripping PSM, you're probably driving a bad line, or being choppy with the controls, and should reconsider your approach in that corner. These cars don't have enough power that you should need constant help from PSM. I normally run 1-2 sessions with it on just to get warmed up, especially at a new track, and then if everything seems pretty safe I switch it off. Again, unfortunately switching it off means you have a constant warning light on, so you'll need to just get used to tuning that one out, while remaining aware of any others that may come on!
Old 01-16-2017, 05:11 PM
dkraige
dkraige's Avatar
Also be extremely wary of other drivers particularly during the first and last session of the day. People tend to get a little excited in the beginning, and a little tired at the end.
First sessions: OOOH RACETRACK, TIME TO GO FAST, LET'S TURN OFF ALL GOOD DECISION-MAKING SKILLS!
Middle sessions: Safe, focused learning time for everybody.
Last session: LAST CHANCE TO SET THAT MAGIC LAP TIME, HOLD MY BEER AND WATCH THIS!!
Old 01-16-2017, 05:33 PM
Slakker
Slakker's Avatar
RBF600 is a really good idea. I didn't know that PSM effected the bleeding process but I use a motive power bleeder, frequently. Don't put brake fluid in it though, just use it to pressure the system, then take it off, add more fluid in the reservoir when it gets low, then pump it back up.
You'll probably gain 10-12 lbs on air temp so I'd start about 6lbs under your target pressure and check it after EVERY session. Also make sure you have a way to air the tires back up for the drive home.
Take a torque wrench with you and check the lugs after first session, and every 2-3 after that. 96 ft/lbs.
Pad sensors can be pulled out and zip tied to prevent wear on them.
Also, to prep, find some good videos of people racing on the track in similar cars and start memorizing their line. If you'll spend just 10min a day doing this for a week or two it will make the first day a much better experience.
Beside that, just relax and have fun. And remember, smooth is fast.
Oh ya, and always listen to Sneaky Pete. He's spot on.
Old 01-16-2017, 05:44 PM
IkoIko911
IkoIko911's Avatar
if your car is manual - take some tape and put it over the parking brake handle....
it is such a habit to pull that parking brake up when you stop your car........... but you really don't want to do that when you come off the track......... your mind will be elsewhere - so tape over the parking brake handle as a reminder!
Old 01-16-2017, 05:55 PM
Sneaky Pete
Just a little humor.....but remember flat out baby flat out
Old 01-16-2017, 06:14 PM
David993S
David993S's Avatar
With your background, you probably already know this:
Someone suggested tire pressures of 36/42 was a good starting point. Those pressures sound quite high to me as a starting point. You don't want to start with normal street pressures as your pressures will rise as the tire temp rises. Different brands of tires build heat and pressures differently depending on ambient temp and track temp so you'll have to experiment a little, i.e. get some advice from someone at the track that runs a C4. The other advice is good, but I wouldn't even start at anywhere near 36/42.
Old 01-16-2017, 06:15 PM
porschedog
porschedog's Avatar
Aim for something cheap
There is no shame in point-bys
have fun
Not a race
Don't lift
Your brakes are better than you think they are
Breathe
Not a race
As noted above, don't be pulling up the brake handle when you pit between runs
Have fun
Not a race
Quick Reply: First trackday on the 996. Tips and/or advice?
