Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Cont. Porsche Models:
Color:
Price (no $ sign please):
Private or Dealer Listing:
Location (Region):
Transmission Type:
Parts Search
Keyword:
Category:
Private or Vendor Listing:
Location (Region):
Item Condition:
WTT: Vitesse 944 Turbo (350hp) for Gen2 996
Old 03-11-2014, 04:19 PM
Mister Quickie
Mister Quickie's Avatar
Default WTT: Vitesse 944 Turbo (350hp) for Gen2 996
Year: 1986
Make: Porsche
Model: 944
Cont. Porsche Models: Race Cars
Mileage (numbers only please): 172000
Options (Please check ALL which apply): Air Conditioning, Foglamps, Power Steering, Power Windows
Color: Yellow
VIN: WP0AA0956GN152538
Price (no $ sign please): $0
Location (Region): NorthEast
Body Style: Coupe
Engine Type: Turbo
Stereo System: None
Looking for
Gen2 3.6L 996 or Cayman
6-Speed, will not consider automatic/triptronic
Prefer Coupe as opposed to Cabrio, or Targa
Prefer Yellow, White, Red
What I have
Street legal track car, passed DC inspection (good until 2015)
In July I bought an SSI maintained 951 to take to the track and over the past 6 months had the car gone completely over and everything repaired/replaced/upgraded (list below) and the interior deleted. I stopped counting around $32k.
Life-circumstances have changed and I won't be seeing a track anytime soon.
Here's the stuff that was replaced within the past 7 years/30k miles:
(in descending order of date)
Specialty Services - March 2014
New thermostat
Radiator flush
RPM - March 2014
New Fuel Lines
Replaced Fuel tank with pressure tested used fuel tank
Adjusted timing/cam belt
Replaced alternator with remanufactured Bosch 120A alternator
Me - Jan/Feb 2014
New battery
Radiator flush
Radiator plug
Replace right door seal
Replace Right window seal
Tighten e-brake
Waterproof cover
Locking lugnuts
Syracuse - July 2013 - Dec 2013
Vitesse Turbo Stage 3R: "At 15psi boost, the stage-III is rated at 310-330rwhp (rear wheel horsepower). For every 1 psi increase in boost, we expect an increase of 12-15rwhp.", Programmable to any setting with included software, On the fly switch between two settings.
Interior delete
1/2 shaft kits
Exhaust welding
Fire extinguisher
Front strut brace
Go over entire car: replace worn hoses, clamps, etc
Headlight delete nose piece
High pressure fuel pump
Hood scoop
New oil pan
New Z-rated tires
Oil change
Oil intake breather with reducer
Power steering hose
Racing seats, seat brackets, seat slider
Repaint exterior
Repaint interior
Rollbar
Sunroof delete
Tune up
Vacuum line
Waste gate line
Rear wiper delete
SSI 2007-2013
Connecting Rod bearings - one
Engine or transaxle mount - Turbo - Both, Engine
Oil pan gasket
Power steering pump drive belt
Repack front wheel bearing
Climate control blower motor resister
Power steering hose - [Includes: Bleed system]
Rear hatch
Replace all hoses to crank case control line
Replace all hoses to idle control valve
A/C System - Complete Charge
Balance shaft bearing housing
Condensor
Control arm bushing [Includes: R&I lower control arm]
Door handle - Outer, Each
Front engine oil cooler behind bumper
Left & right swaybay bushings
Power steering pulley & belt
Reseal oil filter housing to block
Right tie rod assembly
Weld in left & right rad support & install radiator, Includes R&R of front bumper cover, header panel & intercooler, both front head lights
Clutch master cylinder [Includes: Bleed system]
Clutch slave cylinder [Includes: Bleed system]
Cam tower gasket
Clutch master cylinder hose
Right brake light sensor
Trunk hatch switch
Gas tank filler neck cover
Shift lever & socket
Door wiring harness plugs
Exhaust manifold [Includes: replace gaskets]- Turbocharger
Left window switch
Wiper & washer switch
Connecting Rod bearings - all
Spark plug wire set
Clutch kit
Clutch release arm
Crankshaft oil seal - Turbo, standard trans - rear
Hood shocks
Machine flywheel
Hood latch release cable
Strut assembly
Driver side door stop
Hatch seal
Heater control flap drive motor
Rear hatch locks
Transaxle assembly
Camshaft housing - turbo
Crankshaft oil seal - - Turbo - Front
Cylinder head gasket set
Differential side seal
Disc rotor, rear both
Engine Seal Kit
Four wheel alignment adjustment
Horn assempbly -
Left & right balance shaft seals
Left & Right steering rack boots
Power mirros
Stabilizer bar bushing
Timing Belt
Timing Belt Tensioner
Water Pump
Mister Quickie is offline
Quick Reply: WTT: Vitesse 944 Turbo (350hp) for Gen2 996
