03 996 911 Turbo 6 speed, Silver 67k miles Chicagoland area
Year: 2003
Make: Porsche
Model: 911
Cont. Porsche Models: 996 Turbo
Mileage (numbers only please): 67053
Options (Please check ALL which apply): Airbags, Air Conditioning, Antilock Brakes, Cruise Control, Foglamps, Intermittent Wipers, Leather Seats, Power Brakes, Power Door Locks, Power Steering, Power Windows, Sunroof, Traction Control
Color: Silver
VIN: WP0AB299X3S685807
Price (no $ sign please): $45000
Location (Region): Midwestern
Body Style: Coupe
Engine Type: Fuel Injection
Stereo System: AM-FM CD
I really enjoy this car a lot and I am selling it with a bit of hesitation. It drives extremely well, very solid and with no issues. Also extremely quick! I have not tracked or autocrossed it, however, the previous owner did do a couple of track days in it.
Purchased last winter, however, I want to move back to NA and RWD. Most likely a 40th anniversary 911 or up to a GTS if I can swing it. The previous owner only had it a short time as well, but needed to focus on his SCCA race program. I have put about 2500 miles on it and have had zero issues with it. I really do love it, but honestly, I could do with 150 less HP or so. Simply because the power is addictive and I seriously do not want to be a felon every time I am out it in. I also want to do some track days, but a heavier faster car is going to go through consumables more quickly, which means more time on maintenance which I simply do not have.
Comes, all books, manuals, both keys and with a very detailed spreadsheet of records going back to the original owner. I believe I am the 4th owner. It lived in Florida for the first 6 years and 50k of its life. Then Texas and Oklahoma before coming to Chicago earlier this year. I had it shipped up here and it lived in the garage until April and as mentioned it has been put away for the winter. It has never seen snow or salt and honestly, I tried not to drive it in the rain too often. Since 2009, it has seen about 2000 miles a year on average.
The exterior is in very good shape but not free from defects. Currently has a couple of door dings. One on the a-pillar and another on the left front fender. Both hard to notice unless you are looking for them. Also some chips on the lower passenger side towards the rear. Will include pictures of these.
Factory Options
288 - Headlight Washer
440 - Hidden Radio Antenna (in windshield)
567- Windshield Tint
601- Litronic (Xenon) Headlights
939 - Soft Leather Rear Seats
982 - Supple Leather Seats/Trim
X70 - Stainless Steel Door Sills with Turbo Insignia
XSC - Porsche Crest on Seat Headrests
XPD - Carbon Fiber Steering Wheel
X48 - Carbon Fiber Shift ****
X58 - Carbon Fiber Parking Brake Handle
Engine Modifications
Blouch k16/16g upgraded and rebuilt turbos. Some more information on this
http://www.eplabs.net/pdf/996-k16-16g-kit.pdf
https://rennlist.com/forums/993-turb...d-upgrade.html
FVD Ecu Flash
http://www.fvd.net/us/en/Porsche-0/C..._FastLoad.html
GT2 Intercoolers
5 Bar Fuel Pressure Regulator
Agency Power Billet Diverter Valves
BMC Air Filter
997 OEM short shift kit
G-box 2nd gear detent
Sachs Heavy Duty Clutch - done around 54k miles
Over 450WHP on a mustang dyno and pump gas.
Interior Additions
Lloyds “Turbo” Custom floor mats
Sonic MotorSports Carbon Fiber Steering Wheel
Rennline Pedals
Dension Gateway 500 (for iPhone/iPod connectivity)
Beltronics Shifter ZR4 Laser Shifter (hidden in front ducts and on rear license plate)
Wired for Escort Radar Detector & ZR4 Interface with detector mounting bracket
15% window Tint
Battery Tender plug hard wired in for easy plug in
Suspension and Miscellanous modifications
Sumitomo HTR Z III Tires with ~500 miles (295/30/18 rears and 225/40/18 fronts)
Boothe Wheel Locks
H&R 7mm Hubcentric Wheel Spacers front/rear
KW V3 Adjustable Coilovers
GT2 ride height and alignment/corner balance
H&R Adjustable 24mm Rear sway bar
Tarett rear drop links
Braided brake lines f/r
GT3 Brake cooling ducts f/r
Invisibra on front bumper, front half of hood, and headlights
Color matched rear wiper delete.
Some Stock parts included. (suspension, intercoolers) and multiple other new OEM maintenance items with extreme detail taken to keep records of all services or upgrade as they were done.
Service History -
Original owner serviced at Champion
MILES DATE SERVICE
15k Complete 15k service
16k Alignment
29k Radio replaced
29k Alternator replaced
30k 09/01/06 Complete 30k service, spark plugs replaced
30k Oil pressure sending unit replaced
33k Power steering reservoir replaced
33k Passenger side radiator replaced (pin hole leak)
38k 06/01/07 Passenger window regulator replaced
40k Ignition switch replaced
45k Tires replaced
47k Air valve replaced due to check engine light
50k 07/01/08 Complete 50k service, clutch slave cylinder replaced
2nd owner
1/14/2009 53400 Clean & re-oil BMC air filter
1/20/2009 53400 Replace pollen a/c filter, 996-572-219-02-M63
1/20/2009 53400 1 lt Pentosin CHF 202 - power steering & clutch fluid
1/20/2009 53400 Oil Filter removal tool
1/27/2009 53465 Replace fuel filter; Mahle 996-110-253-52-M67
1/27/2009 53465 Replace serpentine belt, Contitceh 999-192-379-50-M21
1/27/2009 53465 Clean MAF sensor
2/4/2009 53600 4-wheel alignment
2/9/2009 53670 Brake Fluid change; ATE SL6 DOT 4 Class 6 (3 liters)
2/12/2003 53695 Agency Power Billet Diverter Valves
2/18/2009 53740 Pentosin Coolant
2/18/2009 53740 Replace left front marker lamp (cloudy)
3/4/2009 53802 Replace plugs; Beru Ultra 14FR-5 LDU Z 192
3/5/2009 53850 Bleed / refill spoiler actuator
3/9/2009 53915 FVD ECU Flash
4/6/2009 54160 Oil & Filter Change; Mahle filter, Castrol Syntec 5W-40 Full Synthetic
4/10/2009 54200 Carbon Fiber Shifter
4/15/2009 54285 Change steering column stalk switch assembly due to broken turn signal function
4/22/2009 54400 Install Sachs HD clutch pressure plate, clutch, t/o bearing, accumulator
5/13/2009 54520 Install Dension Gateway 500 audio interface
6/11/2009 54719 Sumitomo HTR Z III Tires, 15mm H&R rear spacers, 10 long wheel bolts
6/11/2009 54719 Mount & Balance tires
6/21/2009 54745 Install Wheel Bolt Locks
7/20/2009 54850 New Engine Coolant Reservior Cap
8/3/2009 54995 Change transmission & front differential gear lube
8/22/2009 55092 SpeedTech Exhaust, 70mm, 200 cell CATS (used)
9/14/2009 55238 Aluminum Porsche Pedal Set
10/5/2009 SpeedTech 70mm Exhaust Tips & Quiet Inserts – Removed and sold
10/13/2009 K16 OEM Turbos / cores for 16G upgrade
11/11/2009 55484 Blouch K16/16G upgraded turbos
11/11/2009 55484 5 Bar Fuel Pressure Regulator
11/11/2009 55484 Flash Upgrade for K16/16G turbos
11/11/2009 55484 Nuts & hardware for turbo installation
11/30/2009 55560 Dyno Runs, Mustang Dyno
12/28/2009 55738 Lloyds Floor Mats
2/3/2010 55870 Repair & repaint front bumper cover (paint $168, labor; repair $240, paint $224)
2/3/2010 55870 Baysonr Lower Front Lip
2/11/2010 55870 Replace driver's side lower rocker panel
2/11/2010 55870 Replace underseat plastic trim panels
2/17/2010 55870 Replace front underside air duct, #996-575-161-01
3/5/2010 55900 Replace Console CD Tray with Storage Shelf (bought entire center console)
3/10/2010 55960 Invisibra
3/22/2010 56150 Install GT-3 Brake Cooling Ducts
3/22/2010 56150 Install FVD Stainless Steel Brake Lines (FVD B96 355 97)
3/22/2010 56150 Front Rotors (Porsche / Zimmerman Coated - not installed at this time)
3/22/2010 56150 Install Rear Rotors (Porsche / Zimmerman Coated)
3/22/2010 56150 Install New Brake Caliper Bolts
3/22/2010 56150 Bleed Brake System; 2 500 ml bottles Motul RBF 600 DOT 4 Brake Fluid
3/22/2010 56150 Motul RBF 600 DOT 4 Brake Fluid
4/21/2010 56250 G-Box 996 2nd Gear Shift Detent
4/21/2010 56250 Adj wastegates; added 2 turns on nuts. Prior start to crack @ 7.0 psi, now 7.5 psi
4/23/2010 56260 Install Carbon Fiber Center Console
4/26/2010 56630 Replace battery due to small crack / leak on top. No charge / under warranty.
8/11/2010 56935 KW Variant 3 Coilover Kit
8/11/2010 56935 Agency Power Rear Sway Bar Llinks
8/11/2010 56935 H&R Rear Adjustable Sway Bar; 24mm
8/11/2010 56935 Front Top Strut Mounts, Porsche OEM
8/11/2010 56935 Replace outer CV joint boot on left front axle
8/30/2010 57009 Corner Balance
8/30/2010 57009 Four Wheel Alignment, GT-2 Spec
9/27/2010 57505 Replace front hood shocks (996-511-551-01-M24)
10/13/2010 57524 Oil & Filter Change, Mahle Filter, 10 qts Mobil 1 5W30 full synthetic
12/3/2010 58020 Wax; Glanzwax on paint, Rejex on clear bra and spoiler
1/22/2011 58185 Install Rennline Heel / Toe Gas Pedal Extension
1/31/2011 58189 Install "Turbo" scirpt OEM center wheel caps
2/1/2011 58189 Install GT2 X50 Intercoolers
2/1/2011 58189 Turbo hose o-rings (6), OEM Porsche
2/2/2011 58189 Install Escort ZR4 system
2/17/2011 58218 Paint "PORSCHE" logo on brake calipers
2/18/2011 58218 Install Tarett Rear Drop Links, TE-996RDLNK-A
2/18/2011 58218 Install new front side marker lights (others had broken tab)
4/15/2011 58682 Bleed brakes, Motul RBF 600
5/3/2011 59077 4-wheel alignment
5/16/2011 59109 Replace Coils (6), Beru 997-602-104-00-M47
5/16/2011 59109 Replace Spark Plugs (6), Bosch 14FR 6LDU
8/28/2011 59365 Replace transmission mount
9/13/2011 59379 Replace fuel cap (tether broke)
9/13/2011 59379 Misc hardware (plastic rivets, clip nuts, torx screws)
Steering Wheel (bought for core charge for recovering)
Motul RBF600 Brake Fluid (2)
11/6/2011 59979 Sonic Motorsports Carbon Fiber Steering Wheel
11/6/2011 59979 H&R 7mm front wheel spacers & ball seat bolts
11/6/2011 59979 Bleed brakes, Motul RBF600 fluid (1)
Mahle Oil Filter
Oil Filter sealing O-ring
11/11/2011 1 Gallon Mobil Delvac 75-90 Syn Gear Lube
11/11/2011 37mm Boothe wheel locks (2)
11/11/2011 1 Qt Porsche Antifreeze
11/11/2011 OEM Porsche Lug Bolt set with 4 locks
12/1/2011 1 Gallon Porsche coolant (free shipping)
12/31/2011 60213 Oil & Filter Change, Mahle Filter, 10 qts Castrol Syntedc 5W30 full synthetic
12/31/2011 60213 Change transmission gear lube
12/31/2011 60213 Clean & re-oil BMC air filter
12/31/2011 60213 Replace L & R front rubber air dams and radiator outlet trim pieces
12/31/2011 60213 Replace L & R main engine-to-coolant line hoses & retaining clips
12/31/2011 60213 Replace coolant resevior-to-engine hose & clamp
Additional coolant hoses, o-rings, & clamps (not installed)
2/29/2012 60300 C/F Surrounds for key & hazard switch
3/17/2012 60400 Bleed brakes, Motul RBF 600
20/1/12 Passenger side door sill rubber tray
4/10/2012 60830 Driver's side sun visor vanity mirror
7/25/2012 Window regulator; Porsche OEM ($15.92 shipping)
8/24/2012 61451 Install Drivers Side Window Regulator
4/7/2013 61821 Bleed brakes, Motul RBF 600
4/20/2013 61930 New Gold DieHard Battery
5/3/2013 62205 997 Short Shift Kit
5/3/2013 62205 New CRD23 radio *****
9/28/2013 62789 Replace Oil Pressure Sender
9/28/2013 62789 Porsche Oil Filter (spare, not installed)
10/18/2013 62789 Replace front axle CV boots (boots & clamps for one axle only)
10/18/2013 62789 Front axle CV boots & clamps (one axle only, installed by RAC)
10/18/2013 62789 Install OEM Front Rotors (new - purchased 3/22/10)
10/3/2014 62985 Oil & Filter Change, Porsche Filter, Mobil 1 5W30 full synthetic
2/28/2015 63027 Wax; Glanzwax on paint, Rejex on clear bra and spoiler
8/29/2015 63350 3rd owner
9/13/2015 Tint - White Glove Auto Detail
9/16/2015 Rear wiper plug - Artic Silver L92U
12/24/2015 63832 Driver Turbo oil feed leak, and oil/filter-Rotella T6 5w-40 Syn - Porsche Filter
3/10/2016 64382 4th owner
PPI
3/17/2016 64382 Center radiator replacement
04/27/2016 65136 Installed factory exhaust
07/11/16 65883 Adjusted ride height, alignment
07/11/16 65883 oil change
10/12/16 66497 new tires
I do not have 100% of the receipts. None from the original owner and I have not had time to go through the two folders of other receipts.
I did run a CARFAX and it was clean. Sadly I did not download it, so you will have to run one.
Attached is a snap shot of the PPI report I received before I purchased it. I did replace the center radiator and was told the leaks were very minor on the spoiler. The spoiler does operate perfectly and I have not found evidence of more leaking, but obviously it does need to be addressed as they do not repair themselves.
Type 1 over-revs – 32787 – Software increases the rpm limit
Type 2 over-revs – 459
Countless threads out there about this subject that I read intensely and decided it was not a big deal.
I have been on Rennlist for quite a long time and plan to be here a long time, so have tried to include everything I know about this turbo. That said, inspections, questions and more questions are highly welcome! Also if there is something else you would like to see, I will try to get a pictures as soon as I can. It is securely covered and kind of a process to uncover it. Especially the interior, engine bay and frunk.
email is my screenname here @aol.com or call/text 224-622 eighty nine hundred
Thanks for looking!
More to follow!
Thanks, although not complete! I just ran out of time and fly out again, so wanted to post it.
Yes, so wish the roads were not covered with salt - the 996 would be a blast in the snow!
Thanks and yes, sorry there are not interior pictures. Will try to get those today.
Thanks a ton!
Thanks a ton!
Some more pictures. Sorry for the low quality. Some snow here, so could not take these photo's outside, which required a flash. This resulted in the carbon in most of the pics (especially the center console) game out with a green hue which is simply not there. I grabbed on blurry shot without flash which better shows the color.
Best shot of the real color
crack in carbon
LOVE THE PEDALS!! They feel and function great. They do not look to bad either! ;-)
Built in ZR4 - also hardwire and mount for Escort Radar Detector
crack in carbon
