Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Cont. Porsche Models:
Color:
Price (no $ sign please):
Private or Dealer Listing:
Location (Region):
Transmission Type:
Parts Search
Keyword:
Category:
Private or Vendor Listing:
Location (Region):
Item Condition:
FS: 2004 R32 - REFLEX SILVER
Old 08-08-2018, 10:43 PM
TornVeilMedia
4th Gear
TornVeilMedia's Avatar
Default FS: 2004 R32 - REFLEX SILVER
Year: 2020
Make: Volkswagen
Model: R32
Mileage (numbers only please): 76600
Options (Please check ALL which apply): Airbags, Air Conditioning, Antilock Brakes, Cruise Control, Foglamps, Intermittent Wipers, Leather Seats, Power Brakes, Power Door Locks, Power Steering, Power Windows, Sunroof, Traction Control
Color: Reflex Silver
Price (no $ sign please): $12000
Location (Region): Midwestern
Body Style: Coupe
Engine Type: Fuel Injection
Stereo System: AM-FM CD
I have decided it is time to part with my beloved MK4 R32 to make room for another ride in the stable.
I am the 3rd owner of the car and have owned the car for about (9) years. The car has never seen any snow or salt roads. Car had approximately 40k miles on it when I bought it.
MOD's
- K&N Air Induction
- KONI 1150 Coilovers
- Integrated Engineering Camber Plates
- WaveTrac Limited Slip Differential
- 034 Track Density Motor Mounts
- BlackForest Industries - Dogbone Mount
- South Bend StageII Clutch & Lightweight Flywheel
- CarboTech Pads all the way around
Service/Maintenance:
- General Maintenance - Full Synthetic Oil Change yearly (only put about 3k-4k annually on car)
- Brake service as required
- May 2011 - All Ignition Coils Replaced under VW Recall (also fixed TSB on sunroof drain)
- April 2012 - Haldex service w/Filter (58,366 mi) - (Motor Mounts installed)
- June 2013 - Full Inspection by VW/Porsche mechanic - No known issues
- June 2016 - Replaced 1st gear syncro (believed to be mfg defect), Installed WaveTrac Diff, Installed Coil-Overs and Camber Plates, alignment and full inspection (67,844 mi)
- April 2018 - Install new Master Cylinder, Rebuild all calipers, Install (4) new Rotors, bleed brakes, Installed new Thermostat
- June 208 - Flex Downpipe replaced
All maintenance, installations performed by qualified VW/Porsche Mechanic.
Known issues
- Small spot on roof near trim seal where paint is bubbling (See pictures)
- Door sensor on Driver side door inop - Car does not know if driver door is open
- Once in awhile a MAF out of limits code will show up. Inconsistent. No symptoms other than engine light. Believe to be caused by K&N Air System under certain environmental conditions (does not happen often)
- Headlights are a little dull
- Some wear spots on Driver seat
- Some small scratches, wear, etc. I would say less than typical for 14 year old car...car is still gorgeous!
- Wheels on car are NICHE MISANO, Love them but they don't fit properly, if brake pads are new they will rub on the inside of the wheels, could be managed with large spacers. (Will sell car with original wheels)
Other:
- Has new JVC single Din head unit
- Currently wired for Subwoofer
- Have all original parts (suspension, airbox, antenna, etc.)
- Plan is to sell the car with the original Aristo Wheels. Some minor curb rash, etc. on wheels.
Car is located in SouthEast Michigan. It is not my daily driver and stays tucked away in the garage. Always stored in clean, safe garage in winters.
https://www.dropbox.com/sh/2mg4bacp8...0X1NV-BOa?dl=0
ASKING $12k (includes all original parts I have)
TornVeilMedia is offline
Old 08-09-2018, 01:38 PM
FastAlpine
FastAlpine's Avatar
Love the MK4 R32s. Do the stock wheels come with tires? Do you have the stock headunit as well?
FastAlpine is offline
Old 08-09-2018, 02:53 PM
TornVeilMedia
4th Gear
Original wheels are now on the car with a set of Cooper RS3R's (great tires). They are by no means new but they are decent. Rear wheels have 10mm spacers to get the rear tires out a bit (appearance only).
Here is what I have that is original to the car that goes with it:
- Airbox (Car has a K&N kit on it - was on the car when I purchased)
- Head Unit
- Suspension (Taken off around 67k miles) - Shocks and Springs
- Rear Sway Bar
- Antenna (Car has a stubby antenna)
Old 08-16-2018, 12:48 AM
TornVeilMedia
4th Gear
UPDATE:
I just got the car back from my mechanic, the following work was performed:
- New front wheel bearings (Drive and Passenger)
- New CV boot kit on Driver Front Axle
- New Hub installed on Pass Front
- New rebuilt caliper installed on Front Left
- Full inspection, no other issues found.
Also, the original wheels were put back on the car and I put some pics in the folder:
PICS
Quick Reply: FS: 2004 R32 - REFLEX SILVER
