Hoosier tire sizes for 987.2
Old 12-30-2015, 08:35 AM
fhp911
fhp911's Avatar
Default Hoosier tire sizes for 987.2
I'm thinking of changing from MPSC to Hoosier R7 for next season.
I have stock wheels and have been using MPSC 235 in front and 265 in rear.
Hoosiers come in 225/40, 245/40, 255/35 and 285/30 as likely sizes for my car.
Will the 245 and 285 fit, or must I use the 225 and 255?
TIA,
fred
Old 12-31-2015, 03:53 PM
CMS
Former Vendor
CMS's Avatar
Fred- assuming you have OEM width wheels the safe bet is 245/35/18 front and 275/35/18 rears. We have some guys running as large as 255/35 front and 295/30/18 rears.
Let us know if we can help.
TIA,
fred
Old 12-31-2015, 04:55 PM
fhp911
fhp911's Avatar
THANKS FOR THE INFO !!!!
Will those larger tires (245/35/18 front and 275/35/18) fit on my stock wheels, and inside my stock fenders?
or might there be rubbing?
TIA -- I really appreciate your help on this.
fred
Old 12-31-2015, 05:09 PM
Paseb
Paseb's Avatar
it depends on your suspension/lca/camber setup....
i tried putting a set of 245/275 tire combo on a stock boxster S and i was rubbing in front
car was bone stock
Old 12-31-2015, 05:45 PM
Frank 993 C4S
Frank 993 C4S's Avatar
I used to run the 245/295 combo on my Cayman and needed a 5mm spacer upfront and a 10mm spacer in the rear to make that fit.
Old 12-31-2015, 07:25 PM
fhp911
fhp911's Avatar
FRANK -- but with the spacers you had no rubbing?
and what would have happened if you hadn't used spacers?
Old 12-31-2015, 07:42 PM
Frank 993 C4S
Without the spacers I had rubbing on the inside (front and rear) but I have to add that my ride height is extremely low and that I run in excess of 3 deg camber up front on some tracks - should have mentioned that previously.
Old 12-31-2015, 08:04 PM
fhp911
fhp911's Avatar
Any idea if the body is appreciably different between Cayman and Boxster in respect to this issue?
Old 01-01-2016, 09:53 AM
mikew968
mikew968's Avatar
Hoosier recommends 8.5-10" for the 255-35 and 10-11" for the 285-35.
Old 01-01-2016, 02:54 PM
CMS
Former Vendor
CMS's Avatar
As long as you have oem ride height and a reasonable alignment (2-2.5 degrees camber) you'll be fine.
fred
Old 01-01-2016, 03:07 PM
Gary R.
Gary R.'s Avatar
And that was with R6's, the R7's have proven to run a bit wider for some reason and rubbed on cars that had no issues with R6's.
Old 01-01-2016, 03:08 PM
Gary R.
Gary R.'s Avatar
Not getting that with stock A-Arms/camber plates are you?
Old 01-01-2016, 03:28 PM
Frank 993 C4S
Gary - that was actually with R7s. I had no issue in the rear with R6s
Quick Reply: Hoosier tire sizes for 987.2
