Need Help with Race Suit Sizing
All-
I am looking to upgrade my race suit this season and want to take advantage some of the black Friday sales. I am trying to decide between the OMP Evo one, Alpinestar GP tech suit, or the Adidas Climacool.
I have my measurements and found I am between a 54 or 56. The 56 will be huge in areas but I under all of the measurements. The 54 fits in all areas BUT two- shoulder and thighs. I am an inch over in the thigh and over an inch in the shoulder.
My question is can you be over in those measurements or are they absolute?
The safe bet is the by the 56 but I will look like it is too big (I fear).
Does any have experience with any of these three suites and the sizing? I hope to place the order tomorrow.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Get the 56. More room is never a bad thing on a suit. Last thing I want is a suit that is too tight. The air space is part of the 'insulation' during a burn.
I would think being too tight in the shoulder would be very annoying. i bought the OMP last year and since i'm not well, your typical off the shelf type of guy i took advantage of their "custom build". I think it was around $300 extra and basically it was custom made for me. I forget what size was the "closest" but like you, it was good in many areas but didn't fit in others. On their website there is a section where you take a series off measurements and send them the info. the suit is basically custom fit. highly recommended
Go larger. If necessary, buy some nomex thread and have a good tailor do some minor alterations. That's what I do as the suit that fits is always too long in the sleeve.
I have an Alpinestars Gp Tech. I consider myself to be built more typical American, linebacker style. Wide shoulders, normal to thinner waist, shorter legs. The Alpinestars is made more typical euro thin/tall. I bought mine to fit my shoulders, and would not want it smaller there. In the waist, it fits perfectly, in the legs, it's a bit long. However when sitting, it all works very well.
Don't order too small. Plus when you add fireproof underwear, or a coolshirt, you'll appreciate the extra room.
As an aside, I'm really happy with the suit itself
suit sizes
Go larger. You can cinch in the belt if it's larger at the waist. Plus you don't want a smaller suit when sitting it can pull in the crotch area if it's too short
The omp one Evo is a slim cut suit so that would be my first recommendation
We have one or two adidas suits on closeout from 2013. They actually run a little small so a 56 might be the ticket for you
Alpinestars makes very nice gloves and boots but I'm not thrilled with their suits
I've always recommended going to the larger size for customers when they are in between sizes and it's usually the best choice 99% of the time
Good luck!!!
Good luck!!!
I tried the OMP,an Alpine Stars and a Sparco before choosing the Sparco ... although i tried all three in the same size,they all fitted differently with the Sparco having longer sleeves than the other two.
I was lucky enough that the shop had a sitting room where they let you sit in a race seat set on a tire so you duplicate the seating position as if you would be in your car to see if you are comfortable.It made a whole difference in the feel for each suit ...
Cheers
Phil
Cheers
Phil
Thanks,
adidas///motorsport
