Help- tires creeping around the rims
Old 05-18-2010, 01:56 PM
RedlineMan
RedlineMan's Avatar
Solutions;
- Reduce horsepower.
- Use less brakes.
- Make car lighter
- ROUGH UP wheel lips, like 40 grit on a D/A rough.
- Clean tire bead with lacquer thinner. Remember the same release agent that you
heat cycle out of a tire is there too.
- Use NO soaps or sealers.
- Air up to 40PSI and leave that way for as long as you can.
Old 05-18-2010, 02:05 PM
kurt M
Mr. Excitement
kurt M's Avatar
Originally Posted by Land Jet
Hmm, that sounds reasonable and at least would minimize the vibrations from the tire.
I'm surprised people would use something weak like hairspray but have never tried contact cement. It has a much stronger bond.
The "weak" method works well when done right. The rims and tire bead must be cleaned of old slobber and release compounds. I use flash dry solvent, clean rags and a fine wire brush to scuff lightly. After mounting the tires should sit or not be driven hard for a few days before track use.
You might want to read the directions on the contact cement and think a bit. The reason the hair spray works is it is slippery and works as a lube during install but turns grippy after some time. The contact cement works by being brushed onto both to be mated surfaces and the solvent evaporated prior to being mated together. It bonds by grabbing to itself when the two treated surfaces make contact. How you going to mount the tires?
You mentioned that the tires were flipped. Did they rotate on the rims before they were flipped?
Old 05-18-2010, 02:22 PM
Land Jet
Land Jet's Avatar
I've used contact cement many times. Thought perhaps tires could be mounted on the rim dry, then apply contact cement, wait for it to tack up while using some kind of spacing material to keep the tires away from the bead, then inflate when it dries. Don't know if that's possible but was what I was thinking.
Yes they rotated prior to being flipped but I never asked Paul to use the hairspray because I didn't know about it back then.
Kurt, do you know if the X-tra Seal is available locally?
Old 05-18-2010, 04:14 PM
Larry Herman
Basic Site Sponsor
Larry Herman's Avatar
Larry, you could always use these.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Old 05-18-2010, 05:42 PM
kurt M
Mr. Excitement
kurt M's Avatar
Larry, Yes I understand you know how contact cement works but you might not be as spun up on peformance tire mounting. They don't just slide gently onto the rim and are a far harder task if you were to try it dry. Bead damage while dry mounting is not unheard of. Keep it simple. Use the existing method right and it works.
Hair spray on a dirty rim and greasy tire is not the corect method. the tires and rims have to be clean. Offer to do the cleaning of rims and beads after they dismount the old tires.
Old 05-18-2010, 06:11 PM
Land Jet
Land Jet's Avatar
I could do the cleaning no problem. I have to buy a new set of tires anyway and thought I might get them stuck tight from the beginning.
Old 05-18-2010, 06:12 PM
Land Jet
Land Jet's Avatar
I already have a set of track wheels.
Old 05-18-2010, 06:25 PM
rlm328
rlm328's Avatar
No problem
Old 05-18-2010, 07:43 PM
Larry Herman
Basic Site Sponsor
I guess that you didn't get the joke. They are bead clamp rims used on off road vehicles to mechanically "clamp" the tire bead to the rim.
Old 05-18-2010, 08:15 PM
VaSteve
VaSteve's Avatar
If the tire isn't losing air, is this really an issue?
Old 05-18-2010, 08:37 PM
Darren
Darren's Avatar
Well it makes balancing pretty useless.
Old 05-18-2010, 08:39 PM
TRT41
TRT41's Avatar
or Stop using R888s, decent rain tire since it has tread otherwise not worth your time or $$$
Old 05-18-2010, 08:58 PM
lawjdc
lawjdc's Avatar
The Hoosier R6's that I use, mounted on CCW rims, always rotate substantially. Not much noticable vibration until day 2, then the wheels and tires feel somewhat "square" for a few laps, then they are ok for the rest of the day. I asked around about the hairspray solution among some hardcore professional racers - they laughed. So I don't worry about it anymore.
Old 05-18-2010, 11:34 PM
rlm328
rlm328's Avatar
Try the Nitto NT01s or the RA1s. Different tire compound, I haven't noticed an issue as yet.
Old 05-18-2010, 11:36 PM
Veloce Raptor
Veloce Raptor's Avatar
Received 1,416 Likes on 757 Posts
Wait....I am still stuck on my WTF about this...
Professional Racing and Driving Coach
Quick Reply: Help- tires creeping around the rims
