Winch Mount for Enclosed Trailer
Old 05-31-2006, 04:43 PM
ltcjmramos
ltcjmramos's Avatar
Default Winch Mount for Enclosed Trailer
I have a Milemarker winch that I want to mount in my enclosed trailer. I have a diamondplate floor. How are you guys mounting your winch? Thanks
Old 06-01-2006, 01:21 AM
silver44
silver44's Avatar
Default winch mounting
I have a linoleum floor(i think thats how you spell it)...I mounted mine on the floor inside one of the cabinets. Its tucked away and the line clears the bottom frame of the cabinet itself. Of course I had to make a brace and support it so that I would not work loose from the floor. It works like a champ!
Old 06-01-2006, 09:39 AM
ltcjmramos
ltcjmramos's Avatar
Thanks. I had a PM from a guy who did similarly. I was thinking that mounting it directly on the floor might cause some issues with rubbing on the back edge of the trailer at the ramp door hinge area. It must rub there before the car gets high enough up the ramp, no? I was thinking of mounting it high enough to clear that edge when hooked to the car. Not necessary?
Old 06-01-2006, 10:09 AM
AndyT
AndyT's Avatar
are you bolting it to the frame rails under the flooring ? I was told you had to do this. I am going to do a winch soon myself.
Old 06-01-2006, 10:14 AM
Rick
Rennlist Lifetime Member
Rick's Avatar
My winch is mounted to the center frame rail and located inside my front cabinet (see pic below). I've only had to use it twice and it works great - it's remote control so I can sit in the car and control the winch with a small key fob. Make sure it's mounted very solid...there is a lot of weight being put on the mounting when you're pulling a car into the trailer.
Good luck,
Rick
Old 06-01-2006, 10:31 AM
ltcjmramos
ltcjmramos's Avatar
Absolutely. Make sure the rear mounting points of the winch are into the frame rails. That'll be where the major stress will be.
Old 06-01-2006, 11:57 AM
AndyT
AndyT's Avatar
Very good thanks.
Rick, nice trailer ! I just got an ATC but the foor is bare wood. i like the checker pattern : )
andy
Old 06-01-2006, 01:01 PM
Cory M
Cory M's Avatar
I welded a plate between two of the floor support rails, drilled the holes, and mounted the winch to it.
Old 06-01-2006, 04:38 PM
Rick
Rick's Avatar
Andy,
It looks nice but I found it difficult to keep clean and it was easy to damage/dent it. I've since changed out the entire floor to be Al treadplate and love it.
Thanks,
Rick
Very good thanks.
andy
Old 06-01-2006, 05:22 PM
AndyT
AndyT's Avatar
there is a rubber product i was looking at as well. it's got silver dollar sized circles raised for grip.
The Aluminum diamond plate must look great though !!
Old 06-01-2006, 07:36 PM
jrgordonsenior
jrgordonsenior's Avatar
Rick those cabinets look awesome in the V-nose. Is it an ATC and if so, how long and what's your overall take on the rig?
Lt. Col... What trailer did you finally end up with?
Old 06-01-2006, 08:18 PM
ltcjmramos
ltcjmramos's Avatar
Hi John
I bought a 20' enclosed unit, steel frame, aluminum skin, dual-axle w/electric brakes, diamondplate floor, extra 9" height, 4" width. Got a "deal" from a local guy wanting to get it out of his driveway.
Sorry, no wedding invite. We're going to do a small civil ceremony with family only. April's not into any pomp and ceremony. That way I can spend more $ on my toys.
Old 06-01-2006, 09:14 PM
Crazy Canuck
Crazy Canuck's Avatar
Make sure you have a winch plate (heavy plate steel) welded under your floor (from the underside) directly to the frame. Make sure it's thick. Drill your holes . . . mount your winch. When mounting your battery, if on the inside, make sure you have a box with a vent hose which is ventilated to the outside - or mount it on the tongue. The new thing we're doing is mounting a small solar panel on the top of trailers and wiring it to the battry so it will trickle charge. This way when you go to use it the battery isn't dead.
Old 06-01-2006, 09:38 PM
ltcjmramos
ltcjmramos's Avatar
Won't tieing it in with a frame support suffice? The winch base has four holes, and I can tie two into such a support.
Old 06-01-2006, 09:56 PM
Crazy Canuck
Yup.
Quick Reply: Winch Mount for Enclosed Trailer
