CGT rear wing stuck !
Old 05-20-2015, 03:38 PM
Axis007
Axis007's Avatar
Default CGT rear wing stuck !
I left my CGT rear wing fully extended ( up position ) for a photoshoot and did not retract the rear wing. Now the pass side rear wing is down and driver side is up. As i try to use the wing button to extend, i can hear the motor but nothing is happening, is the rear wing operated by a electric motor? Helped by a gas strut ( Stablis ) can any one shed some light on this matter ? Is there a reset button or mode for the rear wing to reset, or is it a visit to the dealer ?
Old 05-20-2015, 03:52 PM
FLGT
FLGT's Avatar
Not sure. Sorry. I vaguely remember reading another post about it here, so might try searching too if you haven't already. Good luck.
Old 05-20-2015, 04:12 PM
bbs993tt
bbs993tt's Avatar
Send a pm to ByeEnzo on this.
Old 05-20-2015, 04:57 PM
Axis007
Axis007's Avatar
thanks gents
Old 05-20-2015, 05:57 PM
neanicu
neanicu's Avatar
This is a very common failure on the 996 Turbos that have a hydraulic and electric wing.
Please pardon me if I'm wrong here,since I do not own a CGT,but if it has a similar system as the 996 Turbo,then what happens is they leak hydraulic fluid by the rams and most of the time will fail the same way you're describing. And that's why you hear the motor trying to retract the wing but there isn't enough hydraulic pressure.
Old 05-20-2015, 06:03 PM
bojali
bojali's Avatar
the wing is actuated hydraulically. The noise your hearing is the pump running. So the actuator has failed. This is a check they do every Major service (4 years) and one of the reasons the rear of the car comes apart, to get to that system.
Old 05-21-2015, 01:35 AM
ByeEnzo
ByeEnzo's Avatar
You have a pm, Axis.
Old 06-18-2016, 04:51 PM
DaveCarrera4
DaveCarrera4's Avatar
Sorry to resurrect this after so long. I can retrofit an eRam all electric wing actuator to the CGT if needed. I currently supply three heights to the 996 and 997 turbo enthusiasts. Eliminates several risks like Pentosin leaks which can ruin the paint at best, at worst, may cause a fire.
Old 06-18-2016, 10:35 PM
smokeygt
smokeygt's Avatar
Sounds interesting. Costly?
Old 06-09-2017, 03:01 PM
DaveCarrera4
Far less than a new set from the dealer.
Quick Reply: CGT rear wing stuck !
