Macan 2014-Current
Speed Limit Display on 2017 Macan
Old 11-23-2016, 09:16 PM
JCBH
JCBH's Avatar
Default Speed Limit Display on 2017 Macan
Hi - does anyone know how to display the current speed limit on the PCM small display on a Macan? I have a demo that we are trying (just ordered a '17 GTS) and was wondering...dealer does not know. On my '16 RS, 981 Spyder, '14 Panamera GTS, i can select it and display it on the small LCD screen to the right of the tach. There is an option to select it on the previous PCM; just wondering if there is a feature/option I need to order to get this feature (which I obviously like). I ordered Nav, Connect Plus...maybe it is tied into Connect Plus?
thanks for any help or clarification on this.
Jeff
Old 11-24-2016, 12:09 AM
mdrobc1213
mdrobc1213's Avatar
Believe the digital speed is displayed lower center of the main display/tach.
Old 11-24-2016, 12:55 AM
JCBH
JCBH's Avatar
I was looking for the speed limit icon which adjusts for whatever road you are on. It is a cool feature but not sure how to enable it on the '17 PCM 4.0. It appears that you are referring to the current speed...
Old 11-25-2016, 11:40 PM
Todd B
Todd B's Avatar
the speed limit signs only display on the main screen. There's no option to display on the small screen like the PCM3 systems. I noticed this right away when my wife brought her S home.
Old 11-26-2016, 04:07 AM
JCBH
JCBH's Avatar
Thanks - that is helpful - how do you enable the speed limit icon on the large screen? Did not see a way to do that. Thanks for your help!
Jeff
Old 11-26-2016, 10:22 PM
Todd B
Todd B's Avatar
Jeff
Bring up the map, hit the OPT button, then it's the SET MAP -> General Settings - > speed limits display, plus lots of other settings. The OPT key works for any main function screen you're on, and brings up the settings for that section.
Old 11-26-2016, 10:23 PM
JCBH
JCBH's Avatar
Will give it a try - many thanks for the detail.
Old 02-10-2017, 01:33 AM
lewisekrantz
4th Gear
lewisekrantz's Avatar
I found it to be a problem for the following reasons;
1. It actually covers up some data from other items
2. It does not recognize school zones
3. I did not find it always correct due to various road changes
Old 02-10-2017, 09:05 AM
NorthvilleStig
NorthvilleStig's Avatar
Certainly not legal in court but it's handy for new roads
Quick Reply: Speed Limit Display on 2017 Macan
