Porsche Cup Cars
Paddle Shift Alternatives
Old 05-24-2015, 12:49 AM
Joe T
Joe T's Avatar
Default Paddle Shift Alternatives
What are the differences between the various paddle shift options - Megaline, Hollinger, KMP, Shiftec? Technical differences between them, pros and cons, and what would you recommend? Thanks.
Old 05-24-2015, 08:19 AM
joeykid
joeykid's Avatar
Joe- I am not a technical guy. I am a driver., I can comment from my experience. I had a cup that I installed the KMP system in. I also now have a cup I installed the Hollinger system in. The Hollinger system is noticeably quicker on the downshifts. It always does as expected and is not quirky. There is a little thing at start-up that can rev the engine if you don't wait 10 seconds to start, otherwise flawless. The components and bits and pieces all appear to be a grade above the KMP system. I am sure others will compare the other systems but for me it is Hollinger.
Old 05-25-2015, 06:58 AM
spg993tt
spg993tt's Avatar
joe, did you have an issue with the megaline in the #997?
i always felt that was a spot-on system in terms of on track performance though no nothing about its durability etc.
for that car or a different one?
Old 05-25-2015, 08:43 PM
Joe T
Joe T's Avatar
No issues with the 3R. For a different car - my '02 996 GT3RS with '09 cup gearbox.
Old 05-25-2015, 09:03 PM
claykos
claykos's Avatar
Cheater
Old 05-25-2015, 09:20 PM
spg993tt
spg993tt's Avatar
why not go with the sme megaline if they sell a kit . that way if you needed to pinch parts in a bind, you can . something getting sent out for service, you can just pull the bit/widget from the other so you're high and dry without pieces. . plus the crew only has to master one system, updates, upkeep, servicing, they arent crossed up with two knowledge bases.
the megaline works else porsche wouldnt have come back to it with all the 991 cups .
Old 05-25-2015, 10:51 PM
Nizer
Nizer's Avatar
Received 1,730 Likes on 916 Posts
+1 Way I would go.
Old 05-26-2015, 07:11 AM
KMR RSR 001
KMR RSR 001's Avatar
I've been considering options for 001 and also concluded the Megaline system is best.
Old 05-26-2015, 09:08 AM
KA MOTORSPORT
Former Vendor
KA MOTORSPORT's Avatar
For any info or inquiry about the megaline feel free to give us a call or email.
Old 05-26-2015, 11:06 AM
TFBoxster
TFBoxster's Avatar
We are in the process of fitting the Holinger kit to an 08 Cup. Nicely engineered piece of kit. We'll be testing it next week so I'll report back then.
We went for Holinger simply as its designed and manufactured by the same company that made the box. Seemed a no brainer.
Old 05-26-2015, 11:10 AM
Joe T
Joe T's Avatar
Thanks to all for the input. Honestly, I believe the choice is between Hollinger (for the reasons stated above as well as my guys are well versed in this option) and Megaline. Seeking input as to which system people feel is better and why. This is helpful.
Old 05-26-2015, 04:59 PM
zip465
zip465's Avatar
I have the Holinger system in my '10 Cup. I can say that the engineering on the unit is first rate, service and support is first rate, and the system functioned as advertised out of the box e.g. no screwing around with settings. I had one of the early systems that had some issues with the blipper solenoid valve - it would stick thus causing long blips when things got hot. Holinger was aware of the issue and sent a replacement part with a different lube system. They have since revised the blipper solenoid and I now have that new unit in place and it's been working without issue. They have also added a new dual channel gear pot that communicates with the Cup ECU and the Holinger control unit. We put that unit in during the recent trans overhaul done by PMNA and have not had any issues as a result of that change.
Comparing the KMP vs. Holinger from and engineering perspective the Holinger is the better system IMO. The Holinger is plug and play from an installation perspective. I've chatted with folks that have both and have driven both and they all have stated that the Holinger system is crisper on the up and down shifts, where the KPM seems to have some system lag. I know the KMP system has a bunch of settings you can tweak to improve performance but IMO that misses the mark, I just want things to work without a bunch of monkeying around.
I know that James at GMG has driven cars with both systems and could probably give you a good assessment as well. PMNA's choice of the MegaLine system speaks volumes and that system looks to be really nice, I only question the choice of not having a pressure storage tank as it seems the compressor becomes the weak link in the system over time.
Cheers,
Old 05-26-2015, 08:35 PM
georgemcf
georgemcf's Avatar
Would anybody be willing to post up some motec log files to compare the up shift and down**** times for the systems?
I run the KMP system as it was the only real system available when it was installed.
Quick Reply: Paddle Shift Alternatives
