Porsche Cayman & Cayman S all generations 1997-Current
Boxster/Cayman Forum Changes
Old 04-24-2021, 08:12 PM
il pirata
il pirata's Avatar
Default Boxster/Cayman Forum Changes
Rennlist will be changing the existing Boxster/Cayman forums to the following: 986 Boxster (already in place), 987 with a Spyder/Cayman R sub forum, 981 with a GT4/Spyder sub forum and a 982 (718) with a GT4/Spyder/GTS/25th Anniversary sub forum. The existing Cayman/ Cayman S forum will be closed and migrated to the appropriate model forum. As there are a very large numbers of threads to migrate and it has to be done manually, invariable there will be some threads that wind up in the wrong forum. If you see one that you believe should be relocated, please use the report button to notify the moderator team. Please wait a week or two for the changes to be made.
il pirata is offline
The following 2 users liked this post by il pirata:
foodbiker (04-24-2021), Pavegeno928 (04-25-2021)
Old 04-25-2021, 06:48 PM
deilenberger
deilenberger's Avatar
Received 1,160 Likes on 767 Posts
Anyone looking for threads that were started here BEFORE 07/07/11 (first mention of the 981 Cayman) can find them in the 987 forum...
deilenberger is offline
Quick Reply: Boxster/Cayman Forum Changes
