957-Check dipped beam-NOT headlamp
Old 04-29-2016, 05:53 PM
JuannaKnowtrooth
JuannaKnowtrooth's Avatar
Default 957-Check dipped beam-NOT headlamp
Replaced xenon headlamp with OEM after check dipped beam error.
Dipped beam still not working.😠
It is a 2008 CTT, so it's not the classic 955 poor connection issue.
The wire harness is appropriately attached.
High beam works fine.
Am I looking at a module failure? Any other ideas?
JuannaKnowtrooth is offline
Old 04-29-2016, 09:37 PM
deilenberger
deilenberger's Avatar
Received 1,141 Likes on 758 Posts
Try swapping modules from light to light, if the problem follows the module you have your answer.
deilenberger is offline
Old 04-29-2016, 09:59 PM
JuannaKnowtrooth
I have no idea how to swap module.
I should check fuse first I guess...I don't know where that fuse is?
Old 04-29-2016, 10:22 PM
8202632's Avatar
Funny u got this error be I got this yesterday when my carrera had a low battery after leaving the door open too long. How old is the battery?
8202632 is offline
Old 04-30-2016, 07:03 AM
JuannaKnowtrooth
Battery is fine. Just had it inspected. Thanks
Old 05-02-2016, 04:14 PM
Rvca3112
Rvca3112's Avatar
My s gets this periodically. I turn the car off and re start it. Doesn't come back on. I get it maybe once every few months
Rvca3112 is offline
Quick Reply: 957-Check dipped beam-NOT headlamp
