Thump thump in middle of car? help!
Old 10-23-2014, 09:17 PM
SKYSTAK
SKYSTAK's Avatar
Default Thump thump in middle of car? help!
My 08 S pepper is going thump thump under my gear shifter only when i decelerate quickly. Any ideas? Loud and banging. Like a tree limb is stuck under the car but up high in the middle towards the front right of center.....
I pulled over; put it in park and revved it up, no problem. I go along without accelerating hard, nothing. I punch it slightly thump under the shifter....
SKYSTAK
SKYSTAK's Avatar
typo, not decelerate, accelerate....
Old 10-23-2014, 09:37 PM
Shawn Stanford
Shawn Stanford's Avatar
AFAIK: The midget with a hammer under the center console can't be anything but the cardan shaft.
Old 10-23-2014, 09:52 PM
996FLT6
996FLT6's Avatar
Cardan shaft likely culprit. How many miles on your '08?. Mike
Old 10-23-2014, 10:04 PM
SKYSTAK
SKYSTAK's Avatar
only happens when accelerating? How bad a hit am i going to take?
Old 10-23-2014, 10:25 PM
Slow Guy
Slow Guy's Avatar
Originally Posted by SKYSTAK
83,000 only happens when accelerating? How bad a hit am i going to take?
depends on if you're using dealer, indy or DIY.
Old 10-23-2014, 10:29 PM
SKYSTAK
SKYSTAK's Avatar
dealer, but this is an acelleration issue? i can drive along fine if i only press the gas slowly and not all the way down anything else it could be? thanks for the help.
Old 10-23-2014, 10:47 PM
C4SJOHN
C4SJOHN's Avatar
It is your rear drive shaft ( Cardin shaft ) this is a common failure....
Old 10-23-2014, 10:51 PM
Chris51080
Chris51080's Avatar
What you are describing is definitely a center support failure. If you get under your car, you will see a center support bearing on the drive shaft. It is attached to a bracket via a rubber ring. This rubber disintegrates over time, and leads to the sounds you describe.
Its an easy DIY if you have an afternoon.
Order the Vertex center support bearing kit, and it'll be good as new fairly quickly.
http://www.vertexauto.com/ShowItem/2...t%20Mount.aspx
Going to the dealer will cost significantly more.
Old 10-24-2014, 12:28 AM
hahnmgh63
hahnmgh63's Avatar
It will only get worse and then if it lets go completely you will have a lot of damage on your hands.
Old 10-24-2014, 02:31 AM
996FLT6
996FLT6's Avatar
If said Cardan shaft- it'll only get worse. You'll be driving 25 mph in a 65 mph speed limit. If u leave it alone dealership or indie will be happy to charge you more. Mike
Old 10-24-2014, 04:01 AM
blackbull
blackbull's Avatar
Fix it now!! As said damage will be catastrophic if you have a failure at any thing above a crawl.
Old 10-24-2014, 11:14 AM
TomF
TomF's Avatar
Mine went at 68k. I went with the Vertex bearing solution and love it so far. It took about 90 mins to install, including repacking the bearing, with the hardest part being removing the rubber from the old bearing with a razor.
My guibo was new looking and the shaft(s) looked great.
Fix it soon. I made it 450 white-knuckle miles after mine failed, at about 75mph, but you have to stay off the gas and accelerate very smoothly...
Good luck with your choice.
Best,
TomF
Old 10-24-2014, 11:17 AM
SKYSTAK
SKYSTAK's Avatar
I'm just hoping that's all it is. I ordered the kit. Only did about ten miles at slow speed after I noticed it. Will drive the 996 until the parts get here. I'm actually going to sell the pepper soon, but dealers want it for free just want to keep it perfect! Thanks to everyone for the help.
Old 10-24-2014, 12:19 PM
Slow Guy
Slow Guy's Avatar
There's really no need to "hope that's it". It's very simple, crawl under the vehicle, grab the driveshaft and try to move it up and down, if it moves more than a very little and you see the rubber donut is torn you know that's it. Porsche (and most aftermarket driveshaft shops) replace the DS because the bearing/donut is pressed on the shaft, Vertex just upgrades the bearing/donut.
When I did mine on the '06 S (I went the replacement DS route) it was a real bitch because the DS didn't want to break free from the rear diff., I had to put it back together (w/out the bolts installed in the rear diff.), block the rear wheels, start the P!g and let the engine put torque on it until it broke free. I wasn't the first to run into that issue.
Good luck.
Quick Reply: Thump thump in middle of car? help!
