Cardan Shaft?
Old 12-30-2014, 10:41 AM
  #31
ProgRockJunkie
ProgRockJunkie's Avatar
Originally Posted by Shawn Stanford
Mine went about 110k. I think that's typical.
Thanks.
Old 12-31-2014, 05:25 AM
  #32
JAGMAN1
JAGMAN1's Avatar
I agree, if I had to guess it's some sort of neoprene.
Old 12-31-2014, 11:48 AM
  #33
Dilberto
Dilberto's Avatar
It's 2.5mm of Butyl rubber.....not acceptable, for a car of this caliber!
Old 01-03-2015, 09:28 AM
  #34
GoatMaaan
5th Gear
GoatMaaan's Avatar
What are the length of the zip ties? I want to order stainless steel ones but they come in 5.9", 8", and 11.8" lengths and I don't want to order too long because they won't be easy to cut like plastic zip ties. 5.9" should be plenty, right?
Also, should I worry about metal zip ties cutting away at the hose, even if it is metal reinforced?
Old 01-04-2015, 08:59 PM
  #35
Dilberto
Dilberto's Avatar
Honestly, tightly-strapped metal zip ties is more likely to cut into the hose pieces than heavy duty 12" plastic ones we used. Since the maximum driveshaft "float" fore/aft is only 8mm....the zip ties merely suspend the hose pieces inside the bearing carrier shell, holding the center bearing steady at all rpms.
Old 01-11-2015, 03:34 AM
  #36
FarAmFreunde
2nd Gear
FarAmFreunde's Avatar
Default Great Cheap Alternative!
Thanks, Dilberto. I did this fix, per your photo and 4000 miles later.....it's SOLID. Zip ties and a stout hose is ALL you need guys.
Old 01-20-2015, 04:17 PM
  #37
user 83838290
user 83838290's Avatar
Mine just went today at 128k miles. Good number for a first shaft considering I modded the shiat out of it and the car's been on dyno about 5 times in total. Plus I drive her like I stole her most of the time
Scary thing the bearing went out while I was driving well north of 120mph. Sounded like I was under fire from mortars... I crippled home, had to get off the freeway for the last 15 miles as all I could do without it banging was about 40mph.
Old 01-27-2015, 08:40 PM
  #38
jo-hans
jo-hans's Avatar
Hi guys,
I am usually on the 993 section but I just recently started reading about the drive shaft bearing issues and the repair options.
My '05 Touareg has close to 170k Kms and starting to experience the shudder, I went under the vehicle to inspect the bearing and it still looks intact but I am sure it must be on the way out. All the earlier Cayenne's and Touareg's having the same issues and a must fix!
Interestingly there is a similar quick fix option from a fella in Germany:
I am not going that route and decided to replace the bearing with an after market one from Hamburg-Technic in Germany. ECS Sells them for $70US
It does mean I will have to disassemble the drive shaft to install the new bearing but all do-able. The bearing support is back ordered so I hope to receive it next week.
Old 01-28-2015, 01:11 AM
  #39
rymo926
rymo926's Avatar
Thx for the info. You have a link to blue rubber kit.
TIA
Rymo
Old 01-28-2015, 12:00 PM
  #40
5thlilpiggy
5thlilpiggy's Avatar
TIA
Rymo
Im wondering that as well.
This is what I could find:
bullet206 3weeks ago
Where did you buy this piece?
kawe mila 3weeks ago (edited)
Please contact kawemila@aol.de to get all information how to obtain this repair kit.
Old 01-28-2015, 01:18 PM
  #41
jo-hans
jo-hans's Avatar
The above info is all thats available on the web. So contact the seller at kawemila@aol.de for more info.
I do know the guy does not ship to the USA because of liability issues. He will ship to Canada and charges 69,00€ plus 13,90€ shipping. (no affiliation)
Old 01-29-2015, 02:10 PM
  #42
Shawn Stanford
Shawn Stanford's Avatar
That's ridiculous. His shipping charge is more than cost of the entire piece - including the zip ties!
Old 02-01-2015, 03:15 AM
  #43
Dilberto
Dilberto's Avatar
Lol, Shawn.....How much R&D actually went towards a fix, that Jimi conjured-up in just one minute?
Old 02-03-2015, 07:01 PM
  #44
jo-hans
jo-hans's Avatar
That blue rubber piece would be good to have in case of an emergency yet still pricey, I'd say carry the cheap "Jimi" material in a emergency bag.
I just received this from ECS so I'll be rebuilding the shaft later this week.
Old 02-05-2015, 06:05 PM
  #45
User 4221
User 4221's Avatar
When doing this, can you shoot some pics of how the CV joint comes apart and re-assembles?
I have a strong hunch I know how it works, but pics would be most helpful.
Quick Reply: Cardan Shaft?
