GTS owners - how to mod the exhaust to keep it in Sport sound mode?
Old 02-09-2012, 03:30 AM
CanyonBlaster
CanyonBlaster's Avatar
Default GTS owners - how to mod the exhaust to keep it in Sport sound mode?
w/o needing to push the sport button on the console (unless also want the other sport settings)? In other words, I want to hear the car all the time, even when I do not want the other sport settings (shift points, throttle response, etc..).
I tried search and was surprised no posts on this. It is likely easy but just wondering if anyone has already done it and knows how.
I have done this on a few other modern cars I have owned recently, a BMW 335& VW R32, etc.. All these two-stage sport exhausts use a vacum operated flap valve.
It is most likely either simply removing the vacum line to the flap valve controlling the second set of pipes, and plugging it with a golf tee and ziptie it up out of the way. Or, manually pull the little arm on the flap valve and tie it off in the "open" position with some firm wire (short piece of hanger wire?) or a couple zip ties.
If no one already knows I'll post up results after I figure it out.
Old 02-09-2012, 10:46 AM
GTS Jay
GTS Jay's Avatar
You already figured it out - 2 vacuum lines, one on each side. Pull, cap the valve side, zip tie the line closed. Take a look under there - they're very easy to see and disconnect - 5mins if you have everything ready...
Old 02-09-2012, 11:05 AM
roberga
roberga's Avatar
^ what he said.
Old 02-09-2012, 11:11 AM
Andy E.
The V8 Porschephile
Andy E.'s Avatar
As long as you are aware that a mod like this will not alter the transmission sport shift setting as well. For this setting to be active, you still have to engage the console-mtd button.
Old 02-09-2012, 09:00 PM
CanyonBlaster
Andy, yes, aware, done this mod to several cars. Having the "ear candy" w/o having to ALSO have the sport throttle response and shift mapping is part of the goal.
I will be able to hear my roar even when tiptoe'ing on the ice and snow, driving in a relaxed mode, etc..
Old 02-11-2012, 01:25 AM
CanyonBlaster
got 'er done. vroom vroom....
Old 08-21-2013, 02:34 PM
ydlee
ydlee's Avatar
Where are the valves located? On the ends of mufflers?
Old 09-14-2013, 02:51 PM
Parf7
Parf7's Avatar
I would like to carry out this mod, can anyone offer instructions on where the items are located that need to be modded?
Old 09-15-2013, 12:04 PM
Andy E.
The V8 Porschephile
Andy E.'s Avatar
There are two vacuum-operated actuators (valves); one on each side of the rear muffler outlet pipe to the rear exhaust tips. You must physically disconnect the linkage to the exhaust valve pivot on each side. They are both accessible from the bottom rear of the vehicle (see attached photo).
Old 09-26-2013, 04:54 PM
crs051767
crs051767's Avatar
And what do we need to do???
Old 09-26-2013, 04:55 PM
crs051767
crs051767's Avatar
Old 09-26-2013, 10:50 PM
westy66
westy66's Avatar
The picture is a little grainy, but it looks like a snap ring of some sort and then pull the pin out. Im gonna try this on my turbo
Old 01-18-2014, 04:57 AM
smartbot
smartbot's Avatar
Has anyone tried this on a 2013 GTS?
Do you have to completely remove the link? Is there a screw connecting it? Or do you just simply pull hard and it will come off?
Old 11-06-2016, 02:42 PM
touareg
touareg's Avatar
I assume this does not exist on a turbo, can the GTS mufler, hoses, valves etc be fitted? I would like an option to be loud then quiet, vs cat bypass pipes.
Old 11-06-2016, 05:51 PM
v10rick
v10rick's Avatar
Here you go, what a deal...NOT
http://suncoastparts.com/product/95504420002.html
Add install labor to that and it becomes ridiculous.
I have plugged the actuator vacuum lines so PSE is always on. It sounds just right to me, no need for a switch to disable IMO.
If you install just the P muffler and tips the cost may be a bit more reasonable.
There was a post recently with a shot of a P muffler on a S (?). It had extra muffler outlets with plugs. If you have the same muffler then maybe just some pipe work for always on sport mode.
Quick Reply: GTS owners - how to mod the exhaust to keep it in Sport sound mode?
