Tuning 924s to early 944 spec?
Old 04-25-2014, 11:54 PM
C.pan974
C.pan974's Avatar
Default Tuning 924s to early 944 spec?
Is my understanding correct that a 924s has exactly the same engine etc under the hood, part for part, as the 81-85 944 only de-tuned from the 126ish kw (170hp) to 111ish kw (150hp)? If so, is it possible to reverse this factory de-tuning without buying any extra parts?
Old 05-01-2014, 09:23 PM
Arominus
Arominus's Avatar
No, it's lower compression, to restore it you need the 10-1 piston set for the motor.
Old 05-03-2014, 08:17 PM
C.pan974
C.pan974's Avatar
So it just has different cylinders/internals? But the rest on the engine is the same right (size, mount location etc)? I could swap the engine out of a pre 85 944 no problem if it came up?
Old 07-17-2014, 08:38 AM
H.F.B.
H.F.B.'s Avatar
Yes, provided you swap just the engine. AFM and DME changed pre 85 to late 85.
Quick Reply: Tuning 924s to early 944 spec?
