High Performance Panamera Headlights
Hey guys,
I wanted to share a recent headlight project I did for a friend on his 2012 Panamera S (Non-PDLS). He wanted better headlights and left the details up to me, here is what I whipped up.
In terms of styling, for me less is more: clean>busy, subtle>flashy, function>form.
The 970 HID headlights are pretty basic in their layout, on the non PDLS headlights there is just a bi-xenon (low + high) projector and a "high beam assist" halogen reflector. PDLS headlights offer a static cornering light and a more elaborate HID projector which will swivel right and left with steering inputs.
Build Specs
- Morimoto D2S 4.0 Bi-Xenon Projectors
- Custom "J" Shield Modification
- Black "Demon Eye"
- Morimoto D2S bulbs
- OEM Valeo D1S-D2S Igniter/Adapters
- Aftermarket "Panamera" Projector Shrouds
- LEDs Removed
- Frosted Acrylic
- Low Gloss Black Bezel and Shroud Paint
The headlights found on the GTS/Turbo feature a black bezel but the projector shroud is left chrome and IMO it sticks out like a sore thumb so I completed the black-out look by painting the shroud, the chrome "high beam assist" bowl was left chrome as to not kill function although to be quite honest it's output wouldn't be missed with the performance of the high beam on the Morimoto D2S projector.
The projector was hand sanded and received a custom "J" -step shield design, the original shield had a very tall step which limited a some light output, the shape of the J is also very pleasant to look at, function + form! The "demon eye" is when the front portion of the projector shield is painted, the end result is when viewing the projector at certain angles, the projector lens will appear that color. In this case with it being painted black, the projector lens is less noticeable and blends in with the black bezel paint. Conversely if the projector was given a white demon eye it the projector lens would look white at some angles and the contrast would make the projector lens really "pop."
The oem HID projector is made by Hella and is commonly referred to as the "e55" projector as it was originally fitted to the W211 Mercedes E55 AMG, the same projector is found on some other European vehicles. It is a "good" projector but there is much that can be improved.
The oem projector's strengths include a good "hot-spot" (on center intensity for distance) and relatively smooth light output. The D2S 4.0 has a larger hot spot, better width, more even light distribution, a sharper and flatter cutoff, and an incredible high beam. The oem ballast has the control module integrated into the ballast so replacing it wasn't an option which is fine as it performs really well! New D2S 5,500k bulbs rounded out the upgraded components.
I ran out of daylight so there is only 1 mediocre photo with the headlights installed on the car, the media representative at Boden Autohaus will take some photos in the near future.
I ran out of daylight when installing the lights so my apologies for the single mediocre of them installed on the car, the media representative at Boden Autohaus will be taking some photos in the near future.
Enough talking here are the pics,
Evan
The Panamera in question, it was at Boden for Vorsteiner wheels, suspension work, and painted calipers.
Build Specs
- Black "Demon Eye"
- LEDs Removed
- Frosted Acrylic
Evan
This is actually very nice in several different ways.
1) The craftsmanship is obvious, and excellent-appearing.
2) The upgrade definitely improves the cosmetics of the front end. Nice.
3) The light output...... wow.....
Congratulations.
I do have a very stupid question... forgive my ignorance here... is this "plug-and-play"? could somebody order this "set" from you and install it fairly easily?
Thanks for taking the time to post this.
Congratulations.
Evan
Functionally they are the same, aesthetically the oem shrouds have square "windows" over the LEDs where the aftermarket shrouds have circles.
Evan
If you are inclined to do it yourself leverage Google, do a tone of research, make sure you have the right tools, and be patient with the project since mistakes with headlights can be very expensive.
Evan
My specialties are BMW and Tesla Model S but I like the improvements I am seeing with the Porsche headlights I am working on and the P-car owners seem to be more responsive to my function-forward approach to modifications where the BMW guys are more focused on aesthetics.
I would need to take a closer look at your headlights to confirm what projector is in there, if it is the "base" projector then options would be smililar to what is in this post. If it is the projector similar to what is found in the Turbo (PDLS+?) then it is a more elaborate system and replacing the stock projector might create some additional hurdles.
If by chance you were referring to a different vehicle all together then let me know what other car you were considering.
Evan
