Gutting Interior: Glue Removal Option?
I've removed everything in the back of my '87 Carrera and now find glue everywhere. I purchased Goof-Off but it's not doing the job nearly as well as I would hope. The glue remains soft and just moves around while remaining stuck to the car. I've got hours into trying to remove the glue and suspect I've made less than a 5% impact. At this rate, it will be my entire wintertime project. What else can I try? Is there anything that might dry the glue? Thank you for any suggestion.
Dan
Dan
3M Adhesive remover works on almost everything. It comes in a can or in aerosol. For the really thick, stubborn areas, try a heat gun (on low!) or a hair dryer (on high) to soften the residue enough to scrape it off with a putty knife or similar scraper. [DO NOT use both methods at the same time!] good luck
Outside wth a respirator,paint on three coats of xylene. Let sit and wipe up. Air car out well. No heat. Did I mention a RESPIRATOR!
Xylene is a universal solvent that is worth looking into. I would insure there is no chance of an open spark or electrical switching. And as the earlier post warned respirator.
Let us know how it works out I'm going to strip a Boxter next.
WRONGLY ACCUSED!
This job is much easier in the winter. Wait for the car to freeze and then you take out a cordless drill with a wire wheel attached to it. That's what I did. You still have to clean the last bit of residue with a solvent but it is much much easier. If you do it in the summer you will be sorry!
uninformed gas bag
(contemplating on whether gas bag is one or two words)
sounds funny but I found gas in a spray bottle the best possible solution, ive used everything under the sun and gas just worked best. open up the garage windows and respirator and your good to go.
also I found cotton fluffy towels worked best in a vigorous circular motion not just scrubbing back and forth didn't work aswell as round and round. Hope you like fumes.
thing is Gas is cheap, I never thought Id ever say that about gas but the amount of solvent needed to remove/soften up the glue is about 3-4 bottle of xylene (you will need it sparingly) so in terms of quantity gas is much less expensive.
Many times I found the best method was to spray the entire area an allow the gas to do its own thing. I cant begin to tell you how much you will need a respirator and a fan pushing the fumes out of the back of the car. Its a tuff job, at times I felt like the glue was never going to get cleaned up but sure enough if you just keep plugging away at it it will be gone. After I had the whole car stripped out of the bulk of the glue I re wiped down the whole area a couple of times to get anything I missed. Removing glue from my hands and arms after I had enough gas for oneday was done by "googone" - I just finished doing this job, sure was a mess for the first few days.
I found xylene soaked shop rag worked great. Let sit for 10 minutes or so and the glue just rolls right off. Well ventilated room and mask. Is a must. The smell dissipates much faster than gas.
