Aim Solo DL via can draining Battery
I know this has been discussed some, but I didn't find a answer ...other than disconnecting the unit each time.
I have a Aim Solo Dl and Smarty cam run via can on a 2016 gt4
The solo DL and smarty cam are turning on any time the can data excites....which seems to be if the wind blows .lol.
Changing the power to a switched source did no good as its still powered through the can line.
Has anyone found a fix for this ?
I have emailed Aim and am awaiting a answer ....
Basic Site Sponsor
Basic Site Sponsor
Received 2,837 Likes
Update to the latest firmware for
the Solo DL, which allows a user set cut off time, IIRC.
The OBDII is live all the time. By law. I connect to GT4 by CAN, which is why I didn't notice it.
I have the latest firm ware update installed 46.03.24
And I have the cut off time at its lowest .....the problem is it turns itself back on.
I am also connected via CAN not through the OBD port.
I have found lots of other guys with new GT4's having the same problem....everyone (to my knowledge is just unscrewing the cables to keep it from happening.
Someone else mentioned AIM is working on a firmware/software update to fix this too?
Basic Site Sponsor
Basic Site Sponsor
Ok, I will be sure (along with others) to try and kick this up in AIM's list, but if you wire the power feed on the CAN/power connection near and at the fuse box so that the power feed is off a "key on" circuit, this will not happen.
I know this because dozens of the GT4 SDL/SCHD combinations I have sold have an add a fuse connector to incorporate this "key on" power feature. I'll post the fuse location shortly but any of the 7.5 amp (or empty next to them on the bottom row) will fix this.
Only the OBDII cars, which require power on all the time at the socket, should suffer from this problem.
Basic Site Sponsor
Basic Site Sponsor
Second page of this guide. Yellow arrow. https://www.dropbox.com/s/xbf2mkdi8s...Guide.pdf?dl=0
Fuse D3 for power will fix this problem for hard wired power, for all GT4.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
Rennlist Hoonigan
which cost no drachmas
The origin of the problem is how the new(er) cars are using their CAN bus. The Solo DL when connected via OBDII and allowed to auto turn on/off, will wake up any time their is CAN activity, which in new cars can be pretty frequent. This wakes the DL up and causes the battery drain. This problem is not unique to the GT4, but effects many cars.
With the current DL hardware, there is no automatic fix for this. The two ways to solve this problem are either unplugging the DL or using the key to turn it off. That way it fully turns off, not just goes to sleep (to be awakened by CAN activity).
But, the CAN connection, like Peter said, is the best connection option and resolves this problem.
So to clarify .......
It is hooked up via CAN and not OBD2. It is also wired to a switched battery source (with the key on) not via the OBD2 port.
The issue is that anytime it gets a CAN signal it turns on (lights up) not recording until speed or rpm requirements are met.
Removing the power from the car altogether DOES NOT FIX THIS , The AIM solo dl has it's own INTERNAL battery source. So if wired to the CAN line and CAN sends ANY signal to the unit ...it will turn on. Of course , after 10 minutes (the min. setting) it will turn off again.
I spoke with AIM several times...and Peter too.
The only way to "fix" this is to stop the CAN signal from reaching the unit......my fix was to wire in 2 relays, one for the CAN + and one for the CAN - I used simple 4 prong relays to "break " the can lines.
When the power (key) is turned on it powers the relay which closes and completes the CAN lines, turning the unit on.
If you are only using the OBD 2 port and are just unplugging the entire unit , you will not experience this problem. I wanted to use the CAN and not have it come on randomly.
Basic Site Sponsor
Basic Site Sponsor
Good question.
Rennlist Hoonigan
I've seen different cars activate the CAN for all different reasons. Physical contacts like opening the door, etc always do it, but I've had other experiences like just proximity with the key fob activate the CAN. Other cars will do it at seemingly random times for self diagnostics in my experience.
Safest is to either disconnect the Solo DL or try the hard power off with the button, not the automatic off.
I just installed a SoloDL w/ SmartyCam on a 2014 981S via CAN ECU and have the same problem. To my surprise it drained the car battery overnight.
Turning it off via the SoloDL off button doesn't keep it in the off state. Setting the SoloDL to turn off via the firmware switch function (I set it to 10 minutes) doesn't work either. I guess the CAN bus is always active and the SoloDL detects some activity and decides to turn itself on. I too installed it via a switched +12 but that doesn't fix this anomaly. I guess removing the CAN cable is the only solution at present. This was confirmed by the AIM Tech Support guy.
NightBlueTTS (09-27-2019)
Sorry to bring this back from the past - but I had a quick follow up. Solo 2 DL, currently connected using OBD2.
It seems that sometime after this was discussed, Aim introduced a way to turn off the auto turn on from ECU activity in the menu. So with the auto start from ECU disabled, I can turn the unit off via the left button, and it stays off even when there’s confirmed ECU activity.
My question is, is this now a safe state to leave plugged in, or is “off” really not off? I do see one red led flashing w the unit off, which I’m guessing means the unit is charging, but in theory once it’s charged, will it stop pulling power? Or will it be a constant drain and should OBD2 connection always be unplugged at end of use to preserve battery?
Just to be clear, I’m not talking about leaving it plugged in for weeks on with the car not being driven, just overnight while I’m at the track.
rcg412 (10-01-2021)
That "do not wake" option does not work on my 2014 981. I emailed aim a year ago but nothing, i have the same issue of the solo 2 dl soldered CAN connection turning it on when i close the door, even if i powered it off manually. I just unscrew the cable so it doesnt run down the aim battery when it randomly turns on. It is connected to a switched power fuse. It does not charge with the car off.
I realize this is an old thread, but thought I'd chime in here.
I had this same issue on my 2018 BMW M2. I'd get a dash warning about a power drain.
I had my solo 2 DL hardwired into my canbus wires.
The solution I cam up with was to build a small 2 channel relay box that completely disconnects the canbus wires whenever the 12v power source to my aim unit was disconnected (have it in ignition power)
This worked great and maybe a solution for those of you who ran into this. If you want more info, feel free to PM me and I can give you a parts list and wiring instructions for what I built. It was essentially a small poastic project box with 2 4 terminal aviation plugs in each side. Enough for 12v positive and negative, and can high and low.
Here's a link to a post where I discussed it and some pictures of the unit I built.
https://f87.bimmerpost.com/forums/showthread.php?p=25645510
my solution was as follows: returned the Solo DL just moments before i almost threw it against the wall or before compressing it in a vice. took my money back. bought a regular dash on sale, went that route. that thing has a problem and 2 replacement warranty units which were supposed to not have those issues , well, they continued to have those issues. super irritating. thing woudl drain the dash and the car, never a good thing.
