Moving from SoloDL to MXL Pista w/GPS
So I have been using a Solo DL with Smartycam for the past season. As I take things out of the car I am going to consolidate to an external dash that will also have expand-ability to external sensors. The Solo DL was a simple OBDII plug direct to the Solo and then my SmartyCam plugged into the Solo.
I believe the Pista is designed to be manually wired in however I know AIM also makes an ECU bridge. My question is this, if I want to go with an OBDII for the Pista would I also get the ECU bridge or do they make a plug and play OBDII adapter? I have a 987.2 so can I just simply tap the Can + and Can - ? Are they right behind the stock Nav unit/Radio?
Thank you in advance...
Rennlist Hoonigan
which cost no drachmas
The MXL doesn't use an ECU Bridge. The bridge was really to allow a SmartyCam to connect to an ECU. What car are you putting the MXL into? That will determine how to connect to the ECU. But, if you're Solo DL connected, then it shouldn't be much of a problem for the MXL.
I also have a Smartycam HD. So I was going OBDII---> SoloDL and then from SoloDL---> SmartyCam...
Thanks Matt!
Basic Site Sponsor
Basic Site Sponsor
Received 3,339 Likes
Paul, I'd connect the MXL directly to the CAN near the fuse box or off the back of the instrument cluster. Also, around the column. You'll get more info and it'll be refreshed more quickly. PM me and I'll be glad to help.
You should have an antenna (five pin plug) with the MXL. You'll need a Data Hub, about $60, to plug into the back of the MXL, then the antenna and SmartyCam will plug into the Hub. All set.
I can provide notes on updating your configuration so that it all works seamlessly, too.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
Rennlist Hoonigan
Here is the AiM document that shows what you will get out of the CAN connection and the general instructions. The CAN connection gives you all of the driver inputs except brake pressure. You'll also get all your engine health measures as well. It's the way to go.
http://www.aim-sportline.com/downloa...us_102_eng.pdf
CAN connection will be much more info, faster data rate, and a little cleaner not having to take up the OBDII connection.
-Paul
Rennlist Hoonigan
It would take an external sensor, but you'll get very similar data from looking at Long G. If you bought the unit in the other thread, you'll need to buy either the second harness or build one. Not too hard to build, but takes a bit of time, pin out, and materials. The pressure sensor is not bad to plumb in.
Basic Site Sponsor
Basic Site Sponsor
Nah, hold off and get it up and running right now, Paul.
I'm sure Matt knows the MXL doesn't have an internal longitudinal g accelerometer in it, but you can use the GPS derived Long G, in lieu of that. So, you're fine for now.
Matt or I can sell you a harness. It's a PITA to build one, and you need expensive tools (which I have, and Matt may, too) to do it right.
You have many more options now...
Rennlist Hoonigan
I never found the Amp connectors to be bad. Plus, if he is planning to just add a couple of channels, it would be pretty easy and cheap to do. The motorsport connectors are another story.
