Next step AFTER Harry's
Rennlist Hoonigan
which cost no drachmas
I think the one setup that was missed here is the standard definition Smartycam. All in one, produces the data file, and gives you the video with data on it real time. Three folks here just scored some last week for real reasonable prices. Seeing how you are in NJ, it's worth looking for one over the winter for a bit and before buying something else new. You can always get the new stuff pretty quick.
Here is what I mean:
Purple - Andy Lally in GT3RS
Blue - Me in a GT4
Red - Me in GT3RS
Different cars, different dates, different drivers...all side by side and sync'd to squiggly lines. You can do this up to 8 videos, though I don't see how that would be helpful.
There is some info on both HD2 and Lite in this thread if OP is looking for more info on the racelogic stuff...
https://rennlist.com/forums/data-acq...d2-review.html
Basic Site Sponsor
Basic Site Sponsor
Received 2,847 Likes
The reason why I was SO glad to become a MoTeC dealer many years ago is that I was finally able to offer one of the most sophisticated, powerful and flexible acquisition/controller/display systems available. Mostly because I was able to get access to the resources and the EXCELLENT training that MoTeC provides it's authorized dealers.
MoTeC has been an integral part of engine management, data logging and voltage control of high end, professional racing cars since the beginning of this technology. As long as eight or nine years ago, I was already seeing top-level professional sports cars, prototypes and formula cars beginning to populate historic racing, where I made my living for so long.
Most of the features we now take for granted in other integrated data and video systems has existed in MoTeC for quite some time. They just require knowledge and practice to begin to use them within i2 Pro in an expedited way to be usedful AT an event, BETWEEN sessions.
Most of my MoTeC-equipped clients and customers who do NOT have access to a full time engineer or DAG (data acquisition guys like MoTeC Joe Hullett, Chris Brown, Matt, Ray Phillips, Elton Wong and many others who work on the weekends in a professional capacity) just DON'T have the time, knowledge or experience to fully utilize the great power MoTeC provides and already has.
As a matter of fact, in racing and track day applications (that have been talked about in other threads as "add-ons" to AiM and other systems), sensor arrays like wide spectrum tire and brake temp sensors, shock pots and aero, as well as sophisticated engine monitoring and chassis stability reports using wheel speeds, the users interested in these SHOULD seriously consider upgrading TO MoTeC, as that is the LEAST frustrating way to use and display all those measures, quickly and cleanly.
Getting back to your question, I have equipped many drivers who function as their own crew and are interested in the ease of use of the newer DRIVER-centric analysis hardware and tools to consider the Race-Keeper and VBOX Video HD2 integrated WITH the MoTeC (using a CAN out from the MoTeC to feed info to be written on the video and compared visually using MUCH easier to use and automated software).
I have also supplied AiM ECU Bridges and SmartyCams to replace the older, obsolete ChaseCam PDR-100's in many Cup cars. These can be integrated with MoTeC to good effect. A the new, very small and rendering on the fly MoTeC camera is pretty good, too, but pricey at $2K.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
Turning back to the OP and original question, there is another next step after Harry's which has not been discussed, and that is optimize Harry's and export to CT for analysis and render videos with RR3. In other words, what is the best combination of elements of a reliable, robust HLT system?
For me, HLT + a good mount (with position calibrated to HLTs use of the iphone accelerometers) plus an OBD II adapter and XGPS160 with GoPro session posed several problems with sensor and sensor connection reliability. Most specifically, the XGPS160 had serious BT connection issues and occasional reliability issue even without BT. Maybe a bad unit, but I've read similar on the forums. Moreover, I have a GoPro Session which HLT does not integrate and control well. Thus, for me, I considered replacing the XGPS160 with a VBOX Sport and the GoPro with a Hero 4 Silver (or Hero5) which are know to be reliable with HLT (maybe not the 5 yet, but it looks like it will be ok).
Unfortunately, this is roughly another $1k expenditure ($400 for the GoPro and $500 for VBOX sport, external antenna, mount, etc.). I'd then still be missing many ECU data points like brake pressure and I don't get instant video review. In fact, even if I wanted to download videos trackside, the way the GoPros are designed, I need to unmount and unhook the unit (power) just to pull the uSD card for download - quite inelegant. Also, ECU data like throttle position through a BT OBD adapter has some serious latency, so once can not rely with particularity on the timing of throttle position in resulting graphs.
Overall, for me to optimize HLT, that's $1k IMHO which is better used towards a more established bespoke system as discussed above.
Basic Site Sponsor
Basic Site Sponsor
Lack of reliability. Latency of information (primarily GPS speed and OBDII throttle and RPM info). Lack of powerful, automated COMPARATIVE software package.
You can dress up a pig, but it's still a pig...
And, you get what you pay for...
Peter-
You mentîoned Waylens early on and it appears to be a very simple set up with bluetooth connectivity and some data.
All the reviews and info ive seen center around its use for recording driving on standard roads- not track events with timing.
Im not expecting it to do everything. You mentioned you are now using it. What has been your experience?
Thx
Thx
AIM w /SCHD for FTW.
Like tow vehicles and trailers, just bite the bullet and get the right one, or you will regret the compromise and then need to "upgrade". Video and data for price of a set of good tires.
Basic Site Sponsor
Basic Site Sponsor
Peter-
Basic Site Sponsor
Basic Site Sponsor
For those looking for video augmentation and insight to their squiggly lines, or a review of "intelligent video" (video that is actionable, due to having measures on it already), the SDL/SCHD rev2.1 combo is great and, in my mind and the hundreds of customers I have sold this combo to, a good value at the price.
For those looking at the linkage between the squiggly lines and the video, particularly those intent on coaching themselves without the lengthy analysis required by separate review of the video and data, other systems do a much better job.
Everyone's needs are different. Everyone's commitment, in time and effort, to learning how to use this stuff is different. No one's motivation for picking one system over another is wrong.
I have recently sold many SDL/SCHD combos to drivers that are in cars that don't even supply any ECU info, something I would not have considered recommending. They're doing this simply because of this combo's automation and ease of use...
It's an embarrassment of riches, all of the great choices available when HLT and RaceChrono folks want to move up to serious tools. I'm just very fortunate to be on that leading crest of this great technology, which frees the sport from the shackles of expensive (and of variable experience, knowledge and motivation) DAG's, coaches, instructors and engineers and NOW easily allows drivers to coach themselves!
Good stuff!
Basic Site Sponsor
Basic Site Sponsor
Yes, RT Video 4, with a DL1, with render the DL1 data to the video real time.
There is also a version that does not need a DL1. It has GPS, an accelerometer, and several inputs which allows a tach input as well as several others.
Ray
Ray
Basic Site Sponsor
Basic Site Sponsor
I'm thinking back when it was introduced in 2009-2010. I forgot they added an all in one.
RT is a very powerful logger/software combination. Al Seim, who's been the US agent for more than a decade, is a great resource. My first GPS logger was a DL1, and I sold them for awhile. But the software and configuration was so complicated and time consuming, it was not practicable for 90% of my customers. The ease of use was not there, like RacePak.
They're SD (standard definition) Video4 was a nice piece when it came out, though.
