2005 Porsche Carrera GT Detail + CQuartz FINEST + Xpel - Presidential Detailing FL
Old 06-17-2015, 02:58 PM
Presidential_detail
Presidential_detail's Avatar
Default 2005 Porsche Carrera GT Detail + CQuartz FINEST + Xpel - Presidential Detailing FL
We recently had the opportunity to work on this very beautiful 05 Porsche Carrera GT. The car had clear film applied when it was new and it was beginning to show its age, so we were brought on to restore the cars finish back to BETTER than new. After carefully pulling all the old film off and removing any remaining residue, the car was then corrected and polished to perfection. The entire front 1/3 of the car, front air channels and rocker panels were wrapped in Xpel Ultimate Paint Protection Film to ensure this Carrera GT stays in pristine condition. Once that was completed, we coated the entire car, including the film, with Cquartz Finest Ceramic Paint Coating for ease of maintenance and to ensure the finish will stay protected for years to come!
Pre-Inspection
If you look closely, you can see we were dealing with DA sanding marks on many parts of the car, which were probably left by the factory when the car was painted. These can be difficult to remove on their own, then throw in a full carbon body and you've added a whole new variable to the mix. Extreme care and caution must be taken while polishing carbon body panels to ensure you are not building up too much heat, otherwise irreversible damage can be caused to the paint finish.
Various machines, pads and polish combinations were used to determine the safest approach. We need to quickly cut away the defects while generating as little heat in the panel as possible.
Watch in HD!
After many hours of cautiously polishing every surface to perfection, the end result is much more depth and clarity to the paint finish. Even on silver, it was a night and day difference.
The tail lenses were also starting to show their age.
We carefully polished each tail lense to restore the depth and vibrance. Something as simple as this, goes a long way in the overall look of the vehicle.
Xpel Ultimate Paint Protection Film is a self-healing clear film that will allow you to drive your vehicle, without the worry of damage from rock chips, road debris, etc. It is resistant to light scratching and if left in the sun or heat is applied, it will begin to heal itself. We also top the film with Cquartz Finest for even further durability, protection, gloss and ease of maintenance. All edges of the vehicle are wrapped where possible, for an extremely stealth installation. In most cases, you can not tell the car has film applied to it.
CQuartz Finest Ceramic Paint Coating
Multiple layers of Cquartz Finest are applied to all painted surfaces, as well as the clear film, for the ultimate protection package. Cquartz Finest is a semi-permanent ceramic coating that will protect your vehicles paint finish and add a tremendous amount of gloss and depth, guaranteed for up to 2 years.
Incredible amount of gloss from Cquartz Finest being shown here!
Completed Shots
Quick Reply: 2005 Porsche Carrera GT Detail + CQuartz FINEST + Xpel - Presidential Detailing FL
