Boxster & Boxster S (986) Forum 1996-2004
Driver side radiator fan not working
Old 08-02-2012, 02:53 PM
Dan Merchant
2nd Gear
Dan Merchant's Avatar
Default Driver side radiator fan not working
So my car is slightly overheating due to the driver side fan not kicking on, the temps are hitting 210+ on a daily basis. Here's what I've done/tested so far:
-Swapped relays from the passenger side that works (Low & High relays)
-Pulled off bumper (removed debris) and made sure it was plugged in
-I ordered a new ballast resistor; I'm going to try & swap the resistor tonight but from what it sounds like it would bypass the resistor when it's on 'High'
-Checked the fuses ( C10/C8) and they're good
I'm going to pull off the fender liner tonight for the ballast resistor. How do I go about applying power directly to the fan to make sure it works and isn't a wiring issue?
Any help would be greatly appreciated!
Here's 2 resources I've stumbled upon as well:
http://www.ppbb.com/phorum/read.php?...04#msg-1509504 (Fan Hack)
http://www.ppbb.com/phorum/read.php?...23#msg-1526423 (Resister Replacement)
Old 08-06-2012, 03:54 PM
Dan Merchant
2nd Gear
Well I figured it out. It ended up being the fan afte rall. I ended up wiring the fan directly to the battery to test it. After fiddling with it for awhile I ended banging on the back of the motor with a small sledgehammer and it came to life! Also, the OEM fan size is 10", hopefully that will be of some help to someone down the line.
Quick Reply: Driver side radiator fan not working
