Boxster & Boxster S (986) Forum 1996-2004
09 400 HP DFI Carrera S engine swap into 986 ?
Old 05-19-2011, 06:53 PM
  #31
whitegold
whitegold's Avatar
Love the project! Great job with the pics and documenting the build! Keep us updated
Old 05-19-2011, 11:37 PM
  #32
harryrcb
harryrcb's Avatar
Thanks, I had to step back for a few days and take a deep breath, not to mention the 3 other projects I have going. Nothing much new, Engine and trans in the car reconfiguring cooling hoses, fuel lines, a/c lines etc. decided I will drop the engine about 1/2 " just for a little extra room for shift cables etc. got the IPD plenum in and installed. will post some more pics tomorrow. Next week I will jump back on that wire harness.
thanks guys for your interest.
Old 05-20-2011, 04:03 PM
  #33
harryrcb
harryrcb's Avatar
Here we are a week or so later and not much progress. Still taking the old harness out. All that's left to do is drop the fuel tank and remove the heater A/C unit under the dash then everythig will be free to get the rest of the harness out. In the meantime I switched back to the engine install. Realized I got the hole wrong for the fronT mount so had to redo it and get it in the right place. Since then I decided I want to drop the motor down another 1/4 " for other clearance issues so spacer for the front mount and repostion the back mounts. Don't know how far I will get with it since I got another job. 01 Boxster that needs water pump, some exhaust mods, softronic tune, light flywheel and clutch plus suspension work (over 100k on the car) still going strong.
THIS IS THE REAR TRANS MOUNT BEING REPOSITION BY 1/4" (NOT DONE)
THIS IS THE REAR MOUNT CLOSER TO DONE (will post picture when I'm done)
THIS IS THE FRONT ENGINE MOUNT REWELDED BEFORE I REDRILLED HOLE
NEW IPD INTAKE PLANUM - THINKING ABOUT POWDER COATING IT RED - WHAT DO YOU THINK ?
THIS IS A MOKUP OF THE INTAKE TUBE THAT WILL HOLD THE THROTTLE BODY
Old 05-23-2011, 08:52 PM
  #34
Brinkley
Brinkley's Avatar
Harry,
PM Sent
Brinkley
Old 06-04-2011, 09:27 PM
  #35
Brinkley
Brinkley's Avatar
Harry's been busy with mine and other projects therefore his crazy project has been slow to advance.
I must say thank you again for the help Harry has given me getting my race car back up and running after a wreck at Road Atlanta.
Thanks Harry
Old 06-07-2011, 01:10 PM
  #36
TrackDays247.com
Former Vendor
TrackDays247.com's Avatar
Man... and I though the 3.6 Varioram swap inot the 911SC was involved....nice!
Old 07-18-2011, 07:50 AM
  #37
insite
insite's Avatar
harry - any updates?
Old 07-19-2011, 07:03 PM
  #38
harryrcb
harryrcb's Avatar
No Sorry - WORK has kept me from playing but I plan on getting back to it in about 2 weeks and hopefully get it done.
Old 04-11-2012, 06:10 PM
  #39
Viperbob1
Viperbob1's Avatar
Harry did you ever finish this swap????
Old 04-11-2012, 09:26 PM
  #40
harryrcb
harryrcb's Avatar
OUCH that's a sore subject. wish I had the time. it's not that I'm stuck or anylthing, I just got so busy in the shop that I have not had time to get back to mine. Bob I sent you and e-mail. Any volunteers want to come over and motivate me to finish or better yet help with my other work so I can get back to my baby? Free beer and luch !!!
Old 10-05-2016, 01:50 PM
  #41
ssburns
ssburns's Avatar
I'm about to undertake a similar project to swap a 2009 3.8L DFI engine into a 2007 Cayman S. Not sure if you've finished your project, but a couple questions:
1) I see that you were able for physically fit the older trans to the revise bolt pattern, but on the newer cars the crankshaft position sensor is on the trans bell housing. So how did you deal with that?
2) Were able to fit the Boxster/Cayman style oil filter housing to the 911 block. They are meant to interchange, but the ports to the block aren't exact. Did you have to do some machining?
Old 10-19-2017, 11:17 AM
  #42
JBurer
JBurer's Avatar
Couple years in the future - has anyone successfully completed one of these swaps?
Old 10-19-2017, 11:06 PM
  #43
ssburns
ssburns's Avatar
My swap has been running since March. Only thing that I don't have working yet is A/C.
Old 10-20-2017, 01:19 AM
  #44
JBurer
JBurer's Avatar
Thanks ssburns - shooting you a private message
Quick Reply: 09 400 HP DFI Carrera S engine swap into 986 ?
