2016 SCCA Street tire wars
Old 05-30-2016, 04:21 PM
  #31
burglar
burglar's Avatar
Originally Posted by Fyrftr50
I am wondering what new rule you are referring to?
He's referring to option XRR 19x8.5/19x10 sport classics, then using the -1" part of the rule you copied above.
A clarification that "X**" options on porsches are legal came out over the winter iirc. "Porsche Exclusive" options listed the brochures are treated the same as the port installed stuff by other manufacturers. They were kind of a gray area before that nobody really tested if they'd hold up in a protest.
Old 05-30-2016, 09:52 PM
  #32
Fyrftr50
Fyrftr50's Avatar
He mentions running 18x8.5 not 19x8.5.
Old 05-30-2016, 10:43 PM
  #33
sjfehr
sjfehr's Avatar
13. Street 4.
Any type wheel may be used provided it complies with the following:
13.4 WHEELS
A. It is the same width as standard and as installed it does not have an offset more than ±7.00 mm (±0.275”) from a standard wheel for the car. The resultant change in track dimensions is allowed.
B. Wheel (rim) diameter may be increased or decreased 1” from the standard part.
Wheel spacers are permitted provided the resultant combination complies with the offset requirements of this Section. On vehicles supplied with an OE wheel spacer, the wheel spacer shall be considered as a part of the wheel. Wheel studs, lug nuts, valve stems (including pressure-relief types), and/or bolt length may be changed. Tire pressure monitoring sensors may be removed.
This one. Lets us run 19" wheel widths on 18" wheels.
Old 05-31-2016, 12:52 AM
  #34
mopar bob
mopar bob's Avatar
That is correct. You could run 18x8 and 18x11 on a 997 since that is the stock width for the 19 inch wheel minus one inch. So install your 315 or 335 Rival S. The 997 GT3 guys are down sizing to 18's so they can run the larger Rival S tires.
Old 05-31-2016, 04:27 AM
  #35
Fyrftr50
Fyrftr50's Avatar
The original post was in reply to Speedemon who has a 996 and was having trouble getting the 255s mounted on his 10" rims. I have a 996 also and was planning to go with that setup but I am now concerned about doing that. The 8.5 rim might be a good option for the 997 or later Boxsters but don't think that's an option for us.
Old 05-31-2016, 12:36 PM
  #36
mopar bob
mopar bob's Avatar
I have 255 30 18 mounted on a 8" rim for the front. I have a 285 30 18 mounted on a 10" rim. They used a ratchet on the tires but they did go on.
Old 05-31-2016, 01:29 PM
  #37
SPEEDEM0N
SPEEDEM0N's Avatar
Thanks for the input guys, second place I got the tires to said the tire beads were bent & that's why they could'nt get it on. No comment on that. They blamed the first guy obviously. The first guy will take them back, remove them from the wheel & take a good look at them to look for damage... Getting a bit worried as the first race of the season is this Sunday...
The specs of the tire recommends a wheel size of 8.5 to 10 inches... So at 8" wide, I'm not that far off...
I will recommend the ratchet method... that's using a ratchet strap aroud the circomference of the threaded area to help seat the bead right?
Old 05-31-2016, 01:30 PM
  #38
SPEEDEM0N
SPEEDEM0N's Avatar
That's a 255 on a 8" rim. ☺
Old 05-31-2016, 01:51 PM
  #39
Fyrftr50
Fyrftr50's Avatar
Unhappy
255 on an 8" rim. My bad that's what I meant. Must have been late when I made that post.
Old 05-31-2016, 02:04 PM
  #40
mopar bob
mopar bob's Avatar
And I should have said that they used a ratchet strap and not a just a ratchet on the tire.
Old 05-31-2016, 10:53 PM
  #41
Mussl Kar
Mussl Kar's Avatar
Europaste on both bead areas of the wheel. Be generous. Tire slime on the tire bead seating areas. This is working well so far. If not then 85 psi and into the hot sun in the back of my suv.
Old 05-31-2016, 11:58 PM
  #42
SPEEDEM0N
SPEEDEM0N's Avatar
Lube is always good.
Old 06-02-2016, 03:52 PM
  #43
Sprockett
Sprockett's Avatar
I just mounted up 255/35 fronts and 285/30 rears on my 996 turbo and while specs would lead you to believe there is a negligible different in diameter a quick and unscientific measure puts the 255 just over a 1/2" taller than the 285. Hopefully my diff survives my first lapping day on these.
Old 06-03-2016, 04:44 PM
  #44
SPEEDEM0N
SPEEDEM0N's Avatar
Front tires are finally mounted. Thanks for everyone's imput. Ready to take on the Street field on Sunday.
Old 06-03-2016, 08:06 PM
  #45
Earlydays
Earlydays's Avatar
There is a new EP tire from Nexen...no reviews yet....it is available in 17", 18" and 19" sizes from Tire Rack.
Quick Reply: 2016 SCCA Street tire wars
