19" wheels for the GT4 wanted...
Old 03-06-2016, 12:51 PM
  #31
jbrennen
jbrennen's Avatar
Originally Posted by mywave
Any other novices considering these inexpensive wheels 19x8.5 and 19x 11 at the TireRack? I'm guessing with offsets of 52 frnt and 42 rear it needs a 3mm spacer?
A spacer decreases the offset number. In order to get those 42mm rear offset wheels into spec to replace a 50mm stock wheel, you'd actually need to remove material from the wheel where it mounts to the hub. That's likely to be a bad idea, and replaces your inexpensive off-the-shelf wheel with a custom-machined wheel.
I've heard of it being done. I would never do it myself.
Old 03-06-2016, 02:42 PM
  #32
mywave
mywave's Avatar
Makes sense, thanks. I guess I'll try OZ's as I won't be competitive anyway.
Old 03-06-2016, 05:49 PM
  #33
sjfehr
sjfehr's Avatar
OZ Alleggerita HLT are good wheels; I bought them (18" 987.2S OEM size/offset) as track wheels but upgraded them to my DD+track duty and usually leave them on full time. They're cheap and light but strong and if you can find them in your size/offset, they're a great way to go.
Old 03-08-2016, 04:15 PM
  #34
allpoints
allpoints's Avatar
I have a set that will fit a narrow body 997.1 C2S or GT3. I don't know if the offsets are the same for your car, but they have the RT option from Finspeed, removed additional material to gain easy access to lugs and it removes another pound per wheel.
Finspeeed F11 forged aluminum wheels with RT option -
19x9 and 19x11.5. Offset for 997.1 narrow body C2S or GT3
standard 5 x 130 lug. Finish is hand brushed with light clear tint.
Old 03-09-2016, 03:04 PM
  #35
HRE_Jurrian
Former Vendor
HRE_Jurrian's Avatar
Just finished up mounting this 19" set of Gold R101 wheels on the GT4. More photoshoots, and videos of the Akrapovič exhaust system will be coming as soon as possible!
Old 04-26-2016, 10:11 PM
  #36
Mussl Kar
Mussl Kar's Avatar
Like any wheel, keep a good eye on them. I retired a set of OZ rears because I found a broken spoke while checking tire pressures in the middle of the day. 4th or 5th year autocrossing them. 30+ events per year. I have bought several sets more since then, but really do give them a good visual check when checking pressure or flipping tires.
Old 05-09-2016, 10:55 PM
  #37
Race Tech Forged
Former Vendor
Race Tech Forged's Avatar
We have a set of 19" RTF Track Spec-5 finished in our RTF Brush in stock selling for an amazing below dealer special pricing.
Wheel Specs:
RTF Track Spec-5
Size: 19x8 F / 19x10 R
Finish: RTF Brush
Car: 987 / 981.2 / 981
The wheels can be re-finished in any color you wish at no additional cost.
If you're interested in this set send us a PM or an email directly to Sales@RaceTechForged.com
Thank you,
Team RTF
Quick Reply: 19" wheels for the GT4 wanted...
