Audio and Video Forum The place to discuss auto and home audio, home theater etc.
Sponsored By:
Sponsored By: Musicar
2001 porsche 911 SQ Audio Build - Mosconi, Ground Zero and Alpine
Old 11-21-2014, 11:57 PM
audioman79
audioman79's Avatar
Next, grills for the door panels were pressed on the 20-ton press.
Old 11-21-2014, 11:59 PM
audioman79
audioman79's Avatar
Door panels was attached back on the door after full deadening to check fit with new grills installed.
Old 11-22-2014, 12:01 AM
audioman79
audioman79's Avatar
Next moving onto the installing the Mosconi mini controller in the center console ashtray. The ashtray was removed the controller was fab in its space.
Old 11-22-2014, 12:03 AM
audioman79
audioman79's Avatar
Oem cables and terminals.
New cables, terminals larger gauge wire.
Old 11-22-2014, 12:07 AM
audioman79
audioman79's Avatar
We removed the OEM amplifier and made a bracket plate from aluminum to house the fuse holder, distribution blocks and relay. All accessories were attached to the aluminum plate by using screw rivets and screws.
Old 11-22-2014, 12:10 AM
audioman79
audioman79's Avatar
removed dash oem mid range and tweeter speakers. the bezel will be to modified for the new plutonium 3" and 1.1" tweeters.
The plastic grill center was cut out and and mdf 3" rings were made and test fitted for angle.
Old 11-22-2014, 12:12 AM
audioman79
audioman79's Avatar
The tweeter pod fabrication part of the pod.
Old 11-22-2014, 12:14 AM
audioman79
audioman79's Avatar
Applied the last coat of filler to the pods. They were wrapped in black vinyl.
Old 11-22-2014, 12:16 AM
audioman79
audioman79's Avatar
The Amp rack installed in the car and wired up.
Old 11-22-2014, 12:17 AM
audioman79
audioman79's Avatar
The top false floor test fit, ready for carpet.
Old 11-22-2014, 12:18 AM
audioman79
audioman79's Avatar
The false floor panel and amp grill cover then wrapped in black carpet.
Old 11-22-2014, 12:19 AM
audioman79
audioman79's Avatar
The false floor and grill wrapped in black carpet.
Old 11-22-2014, 12:20 AM
audioman79
audioman79's Avatar
Grill cover removed.
Old 11-22-2014, 12:21 AM
audioman79
audioman79's Avatar
The LEDS in action.
Old 11-22-2014, 12:22 AM
audioman79
audioman79's Avatar
center console and driver seat back in the car.
Quick Reply: 2001 porsche 911 SQ Audio Build - Mosconi, Ground Zero and Alpine
