Ultimate Motorwerks 997TT Tuning Special $975.00
#107
Johnny DB, I'll probably do that in the spring as she's all tucked in for another Alberta winter.
I'm new to all this....so it's basically a plug and play unit as I understand? What's involved in the install process? How safe is it on these cars?
Alex
Alex
#108
Call Kevin at UMW, he will provide all of the details. In a nutshell -- he sends you a datalogger to datalog your car then he customizes a tune for your car based upon a variety of factors. You install the tune via the datalogger which plugs into your obd2 port.
#109
Kevin can answer all of those questions better than I can. Feels like a different car for sure and worth every $$$.
#110
Can anyone share their experience with this tune and explain what it does exactly and how much power gain it gets. Can this tune potentially add any problems down the road?
thanks
thanks
#111
Alex, I have a plug and play option. The more popular option is to download the ECU file and datalogging thru a computer to email me the data. Again, it's either or a combination of both.
Psup4s, Ultimate Motorwerks tuning will deliver more torque at lower RPM's thru the RPM band. You will be able to stay in a higher gear and not have to downshift. Typical power gains will vary between 50HP and 65HP depending on fuel octane, exhaust and location (ambient temps) I tune conservatively based on the logs that you provide me. Feel free to PM me or call 360.805-9066. If you email me, I will email you logs and info. I will take the time to explain the info and data. If you look at Saabin's threads on Rennlist you can see is data and dyno sheets as he upgraded his car in real time. Others have posted there results..
#115
Get the tune ! whatever you pay it will be worth it ! ive had several tunes from others and there is not a single one of them I have dealt with that will go to the lengths that Kevin will to make sure you have the best tune for your specific car.
#116
I might be out to visit my mom and family that live in Aylmer (now Gatineau ) sometime this spring...so I may take you up on your offer Johnny DB!
#118
#119
