home at last. new to me 997.2 GT3
Fantastic looking motor and congratulations. As great as the GT4 is it will never be a 911, nor a GT3. Enjoy one of the finest analogue driving experiences out there . All the best.
*teaser*
some things in store:
1) GT3 script decals
2) OZ wheels (track set)
3) Function-First shifter
4) Coolant hose welding
5) LSD rebuild with cup parts
pics to follow...
pics to follow...
Big congratulations!
When I had my RS go through a PPI 3.5 years ago with 59k miles the service guys told me that these motors live for being used and that mine was in perfect health. I learned early on to enjoy every mile...as I know you will too! I'm a very 'bad' collector in that way. Hahahahahaha!
Brought my GT3 to Tom and his team at TPC Racing
My order business was:
1) Coolant line welding. Interestingly, there was another GT3 there with it's engine already out getting the same service. Except that, it had been pinned before. Coolant was leaking at the line inserts. TPC opts to weld and pressure test for weld integrity. They also check that mating surfaces are still level/true after the heat cycle.
2) Limited slip differential rebuild. Mine had degraded to an open diff.
Initially, I wanted a Guards rebuild, but was steered toward a rebuild with Cup internals. Hopefully, still an upgrade over stock.
3) Function First shifter install. Less slop and 15% throw. I'm hoping this will clean up the travel from 2nd to 3rd.
4) More track oriented alignment and corner balance.
Definitely not going to be cheap. But I figure, do it right, do it once.
rear bumper removed
2016-12-14_08-12-45 by Neil Lee, on Flickr
engine dropped!
2016-12-14_08-11-54 by Neil Lee, on Flickr
clutch inspected/measured. over 95% remaining
image2-1 by Neil Lee, on Flickr
transmission separated. differential disassembled.
IMG_6611 by Neil Lee, on Flickr
3 of 6 coolant inserts welded. and pressure tested for 24hrs to assure integrity.
image1-2 by Neil Lee, on Flickr
more to follow....
rear bumper removed
engine dropped!
more to follow....
.1 or .2 that had the leaking coolant joints after being pinned?
more to follow....
more to follow....
Agent Orange
Either method can be prone to failure if not done right. And vice versa. Whichever method you choose is fine as long as the person doing the work knows what they're doing.
Can't go wrong w. TPC either way. Great bunch of guys, super knowledgable and I'm grateful that they continue to support our platform.
7.2 gt3 suspension is well sorted in stock form for tracking... just get proper alignment and bars sorted for your style of driving and tracks frequented
dsc may help but only marginally... unlike 7.1's where the front end needs a lot of help ... dsc plus front springs minimum or just start all over
small update.
-full paint correction and detail
-full front + rockers/fenders XPEL Ultimate application
-side decals application *edit* just noticed, the small black stripe forward of the front wheels are flipped/backwards....
I've got black OZ wheels awaiting new RE71R rubber (my track set)
The OEM set has seen it's share of wear after 6yrs, planning on getting them repaired and refinished. Considering a slightly darker shade of gunmetal than what is pictured now.
