Removing bumperettes fill in gap?
#32
#33
Is your car paint code, B4, carrera white ? I sent 3 to get painted with that paint code. Will PM you after I get back.
Beautiful machine. Is that car an ex-norcal car ? If so, i met the prior owner, he said it was 1:1 for non-rs in that color. I like your style with license plate frame, i was thinking of going similar,
#34
That looks great Enrique. Have you weighed the warts and supports that you removed? Any thought to making these for the 996 crowd?
#36
The plastic weights 178 grams and the hardware (with caps) weight 48 grams. So net, i'm adding 200 grams back. I'll re-weight when painted.
Thus far, for sure weight
the rear bar, initial weight :5,660 grams ,
after removing the aluminum warts : 4227 grams
*edit* found one painted bumperrete in my home office
I'll weight oem plastic warts: 138 grams each x 2 = 276 grams
I'll weight painted panel w/ hardware:
Yes I also would like to make it for the 996. I'm suppose to meet the owner of my prior 996T sometime within next 2 weeks. Will have his car on the lift, 3d scan etc etc. Hoping i can get someone a bit more local (he is 100 miles north of me), therefore i can do several prototypes like i did with this one. Over 20 revs on CAD alone, several 3d scans, and several actual print outs and re-measure. Not as easy as it looks.
You sir, have my favorite 911. The envy is HIGH!
#39
Thank you. Very nice RS! Accomplished the same for much less and wont be able to tell the difference and still keep OEM bumper, which is the point.
#40
Originally Posted by F1CrazyDriver
Is your car paint code, B4, carrera white ? I sent 3 to get painted with that paint code. Will PM you after I get back.Beautiful machine. Is that car an ex-norcal car ? If so, i met the prior owner, he said it was 1:1 for non-rs in that color. I like your style with license plate frame, i was thinking of going similar,
#42
Sorry for crappy picture. Busy day. Supplier 1 epic fail, did not paint plug caps. Waiting on supplier 2 to deliver painted goods, however i got installed mean time as i need to drive the car. Need my GT3 fix.
#44
I'm leaving on business trip for 3 weeks - however Alex should be able to help while i'm away.
#45
^^Is that the finished product?
