White Porsche 997.2 GT3 BBi Roll Bar Install with Reinforced Gussets
Basic Sponsor
Attachment 1344394
White Porsche 997.2 GT3 BBi StreetCup Roll Bar Install with Optional Reinforced Gussets
(Click on images for higher resolution)
We took delivery this White Porsche 997.2 GT3 and installed our Street Cup Roll Bar, in our Standard Satin Black Finish, to properly mount harnesses and increase protection. Our bar features 4130 chrome moly steel tubing (1.5" x .120" main hoop & 1.5" x 0.95" rear hoops) for excellent strength to weight ratio. With our sensible approach, the 2 piece design allows the bar to be mounted to the front seat belt mounts and to the rear strut towers (stronger mounting points). The bar utilizes "X" braces on both front and rear sections and each joint has been meticulously TIG welded by hand. For increased strength and rigidity, this bar has optional reinforcement gussets on the main "X" Section and on both sides of the main hoop.Bolt-in installation is accomplished by using Inner Diameter Tube Clamps that are CNC turned and milled for a precise fit. These unique joints allow us to eliminate the more traditional slip fit tubes with an unsightly through-bolt and nut. Here are additional pictures and information that that we would like to share:
BBi Autosport Porsche 996 & 997 Street Cup Roll Bar
Features
Beauty Shots of the Cage's Welds
Beauty Shots of Installed Roll Bar
International shipping is available and wholesale inquiries are welcomed. BBi Autosport products are also available worldwide through our growing dealer network in North America, Latin America, Europe, Middle East, Africa, Asia and Pacific. BBi Autosport is always actively working to expand our dealer network worldwide to grow the distribution of our products and better serve our growing client base. For all questions and inquiries, please email Jerry@BBiAutosport.com or Sales@BBiAutosport.com
Features
- Made from 4130 chrome moly steel tubing (1.5" x .120" main hoop & 1.5" x 0.95" rear hoops) for excellent strength to weight ratio
- TIG welded and utilizes "X" braces on both front and rear sections for superior strength and rigidity
- Mounts to front seat belt mounts and rear strut towers
- Utilizes laser cut mounting plates & inner diameter tube clamps that are CNC turned and milled for a precise and seamless fit
- Designed to work with stock or any aftermarket seats on the market
- Can be used with stock seat belts or 6 point harnesses for track use
- Designed to work with wrap-around style harnesses while optional eyelet bolt provisions are available for clip-in harnesses
- OEM fit & finish. The main hoop contours entire arch of the roof with an even 3/16 inch gap
- Finished in satin black powder coat. Other colors available
- Designed to fit all models of the 996 and 997 chassis including the Carrera, Turbo, GT2, and GT3 (excluding cab models)
- Bolt-in installation requires no drilling and minimal carpet trimming
- Compatible with models equipped with Bose Sub-woofer
- Made in USA
Bringing Passion, Artistry, Craft to the Porsche Tuning Industry
Southern California's Porsche Performance Tuning, Engine Development,
ECU Software Tuning, Custom Fabrication, Race Preparation & Factory Service Center
Website: www.bbiautosport.com Email: sales@bbiautosport.com Phone: (714) 843-0200
Follow Us On: Facebook & Instagram
Basic Sponsor
