997 GT2/GT3 Forum 2005-2012
Trickle charging question
Old 09-09-2015, 11:35 PM
mootsvamootsrsl
mootsvamootsrsl's Avatar
Default Trickle charging question
Guys when trickle charging your battery do you completely shut your hood down or do you leave your hood partly open? I feel that closing the hood completely could crimp the battery tender cord and also fear that leaving the hood partially open, the lights would stay on.
Old 09-09-2015, 11:39 PM
ilko
Agent Orange
ilko's Avatar
You're overthinking it. Close the lid all the way, the hood is not an airplane door, it has a rubber seal around it and won't hurt your cable.
Old 09-10-2015, 12:40 AM
r6elmo
r6elmo's Avatar
i leave my hood open or just unlatched. the light goes out after sometime or a few hours. that way i do not have to pop the hood again to undo the cable and drive off. saves me a step. whatever juice you lose from the hood open is recovered by the charger.
Old 09-10-2015, 01:51 AM
forhamilton
forhamilton's Avatar
I close it. No problems
Old 09-10-2015, 01:58 AM
golfnutintib
golfnutintib's Avatar
i use the cig lighter
Old 09-10-2015, 05:07 AM
GCP
8th Gear
GCP's Avatar
i bring the cable out up near the windsreen
Old 09-10-2015, 10:47 AM
cscrogham
cscrogham's Avatar
^This.
Console or hidden one by passenger's left knee.
Old 09-10-2015, 10:50 AM
RAudi Driver
RAudi Driver's Avatar
Received 2,734 Likes on 1,637 Posts
I leave my hood closed and unlatched, cover on the car and everything is fine. I never knew that a light stayed on.
Old 09-10-2015, 11:03 AM
dave292
dave292's Avatar
I leave the hood unlatched also. The light does go out. I also leave the drivers side window down. I've had to jump two different 997.2 cars that have had either the battery go bad or the charger go bad. Each time it's been a pita to jump the car via the emergency fuse box method because you couldn't open the hood with the switch on the door sill or the key.
Old 09-10-2015, 11:10 AM
jonwb
jonwb's Avatar
I haven't wintered my GT3 yet, but if you're worried about the light, you could just pop out the bulb I'd think.
Old 09-10-2015, 11:52 AM
dave292
dave292's Avatar
The light goes out automatically after a few minutes.
Old 09-10-2015, 12:05 PM
BGA23
BGA23's Avatar
Originally Posted by cscrogham
^This.
Same and I close the door like normal, cord is fine.
Old 09-11-2015, 09:04 PM
mootsvamootsrsl
Thanks for the info guys
Old 09-11-2015, 11:52 PM
ShakeNBake
ShakeNBake's Avatar
^This.
+1, and door closes no problem.
Old 09-11-2015, 11:55 PM
Marine Blue
Marine Blue's Avatar
+1 Installed the quick connect pigtail that comes with most chargers and run the wire up towards the windshield. It tucks in just under the hood when not in use and I can easily connect to it without opening the hood.
Quick Reply: Trickle charging question
