997 GT2/GT3 Forum 2005-2012
9500ci Installation
Old 05-09-2016, 10:08 PM
  #31
OpieT
OpieT's Avatar
I have the same, works very well actually. I suggest checking out the wiring diagram (page 5) and following the wires. Start with the fuse box...disassemble as your curiosity leads you. LINK
Old 05-12-2016, 01:49 PM
  #32
arr0gant
arr0gant's Avatar
thanks! Found the USB port, downloaded software. Going to check for firmware updates!!
Old 05-16-2016, 08:01 PM
  #33
Tiesto996tt
Tiesto996tt's Avatar
Originally Posted by JB911
It is my car BTW...
I took everything apart tonight, traced the wires and found the Interface just ahead of the gear shifter under the console. There was a mini 2 prong 2amp fuse, all fuses were ok. Then I removed the control module, pressed the power button and it turned on.
What a mission!
JB
Mine just stopped working since I changed a new battery last week, Called Escort and they told me to trace power button to the control module. Found out my daughter was messing with the DIM button so it was off. I got all excited when I hit the button and it came on to Auto mode. I then started my car on Friday and now it is completely dead. No power source!
Old 05-16-2016, 08:17 PM
  #34
arr0gant
arr0gant's Avatar
Plugged in two diff usb cables and Windows 10 doesn't find the driver. Not sure what to do now...
Old 05-16-2016, 09:53 PM
  #35
OpieT
OpieT's Avatar
You'll probably have to disable driver signing in Windows 10. Google the how to on that and you should be able to do it.
Old 05-21-2016, 09:35 PM
  #36
arr0gant
arr0gant's Avatar
Not a driver signing issue. USB Device Not Recognized error. :[ X-band and POP work but nothing else... Maybe next thing is to take out the receiver and send it in?
Old 05-24-2016, 12:49 PM
  #37
arr0gant
arr0gant's Avatar
Received a new RJ cable to USB, traced it back to the interface and plugged it in with new USB cable. recognized and detected the 9500ci, started the update and then froze. Waited about 10 minutes and tried again, same thing over and over. Now I get no display. Called Escort, was told the interface and display were likely corrupted. :/
Have to send it in; since it's software related, should be free to fix...
Quick Reply: 9500ci Installation
