Center brake light modulator
Hello- I've used a brake light flasher before on my motorcycle to help keep me alive in LA traffic- and am considering applying the same to my center brake light just to help with visibility to dissuade rear-enders. I see Fiats are incorporating this feature.
Anyone else do this? If so, any install location tips? Here's what I'm considering:
Please don't. Nothing worse than sitting in stop and go traffic on a rainy night with everyone's 3rd brake light flashing constantly.
Do you remember I the 80s when 3rd brake lights were first added, a couple years later the manufacturers "upgraded" the feature so they would flash when the brakes were initially spied, then after a few second delay, they would remain on solid - it became ridiculous when enough of these new cars were bought and on the road, and they eventually abandoned it to not flash.
Plus, if some idiot is looking down at their phone while they're driving, you're little blinking light won't do anything anyway.
^^^^^ totally disagree. I think a triple flash to solid is a fantastic feature. Kias do it right. Quick flash then solid within a second. This is a simple mod if you're electronically inclined. You could even adjust the flash frequency with a potentiometer on a simple breadboard. Lots of options here and I think the one you chose is a good one.
I'll take this a step further.... can we get ALL of them to modulate a la Cup Car style? Been dying to have that scare someone.....
Amazon Amazon
Amazon Amazon
I do think it's an effective attention grabber- at least it grabs mine in the corner of my eye when I see it on more and more of the smaller cars. Until the laws get enforced better to crack down on texting habits while driving or smoking weed in the car, I'll take my chances on irritating the occasional curmudgeon if it helps prevent the rich millennial perched up high in her G wagon from plowing in to me.
Please close the loop and share your opinion when you get it installed. I am curious to know if you will get a code on the dashboard (check stop lights).
Yves
Yves
Boys if we can figure out which wires are what on the brake pedal then I can do this TONIGHT. I have the accelerometer based unit ready to go, plus a backup!
I got mine in this weekend on my cab. Actually pretty easy to do once you get over carefully prying out the center brake light- i only lost two clips in the process but the clips are available separately if you lose or break one. The unit itself is about the size of a nickel so it tucks away just fine and I configured it in the garage with the door down so that I could see the reflected flashing light behind me. I think the accelerometer function might come in handy on LA roads where rush and stop traffic is "normal" I have a 6 am commute to work and am pretty bleary-eyed myself- so hopefully this gets some other sleepy driver behind me to perk up in time to prevent careening in to me!
This is the one I went with:
http://www.3rdbrakeflasher.com/brake...6246175dd3a0af
Alex - which make/model do you have? Did you end up installing it? Thanks!
[BTW, I have an aftermarket fixed wing that has its own third brake light so I'll be putting this add-on unit into my engine compartment (rather than on the brake pedal switch) because I already made the original wiring accessible for the wing brake light.]
