Porsche 997 LED License plate Lights OEM Upgrades
Old 01-23-2014, 05:35 PM
DELREYCUSTOMS
Former Vendor
DELREYCUSTOMS's Avatar
Default Porsche 997 LED License plate Lights OEM Upgrades
Looking for the perfect visual upgrade for your vehicle? New, OEM Replacement License Plate Lights will look absolutely terrific in your car. Increased visibility of your interior makes these the obvious choice for a quick and easy visual enhancement, making you stand out from the crowd and get you closer to the show-car you always wanted
Description
Precision engineered, these 7K White License Plate Lights are designed to perform and outperform any competition. The DRC LED License Plate Lights replace your existing License Plate light Halogen Bulbs to instantly bring your vehicle's appearance to new life. LED License Plate Lights are the most cost effective way to improve the appearance of your car and give you the styling you deserve. Each set is constructed of the highest quality components. Our LED License Plate Lights are the newest style of interior lighting available on the market. These LED License Plate Lights are your way to get that racing look. These LED License Plate Lights are a technological breakthrough in manufacturing. The result is a more powerful LED License Plate Lights installed directly instead of the existing factory halogen bulb.
MATCHES OUR DRC TAIL LIGHTS AND DRC BUMPER LIGHTS
For Show and Offroad use only
Note: if for any reason you decide over time that you want to remove the LED kit, the process can be reversed.
DRC LED License Plate Light Bulb Package Contents:
-One (1) Packaging Box
-Two (2) 9W LED License Plate Lights Housings
-Two (2) LED Resistors
-Two (2) LED Capacitors (IF NECESSARY)
-One (1) Brochure/Installation Manual
1 YEAR REPLACEMENT WARRANTY.
Install Video 1
Finished Install Video with LED Tail Lights on a 997 Turbo with the Red Fog LED modification - Error Free
Easy Online Ordering at delreycustoms.com
Also Check out our install Contest while you online
Old 08-23-2016, 05:09 PM
Long Islander1
Long Islander1's Avatar
Bought these. $22 and they work and act the same as the ones $79+
And they were delivered in 1 day
http://www.ebay.com/itm/152118817520?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old 08-23-2016, 06:49 PM
3Series
3Series's Avatar
I replaced the bulb with an LED one, without adding a new housing, resistor and all that other stuff that needs to be stuffed into the cover. It's prob not as bright as these, but I really want or need to light up my rear plates for a multitude of reasons. I also think the bulb replacement looks good, it's a subtle change.
Old 08-23-2016, 07:37 PM
SoCal C2S
SoCal C2S's Avatar
All my LED lighting is from Del Rey and installed by Del Rey.
Maybe I paid a little more but it worked seamlessly when I left the shop and still works 2+ years later.
....and it's a real shop, not a faceless website.
Quick Reply: Porsche 997 LED License plate Lights OEM Upgrades
