Clear bra removal paint peel?
Old 12-14-2012, 12:50 PM
Knight
Knight's Avatar
Default Clear bra removal paint peel?
Has anyone actually removed a clear bra off non OEM paint?
I realize OEM paint is usually no issue for peeling.
You hear 2 sides of the story these days, those saying def no peel if paint cured properly, others claiming it's so possible esp if the bra has been on for say 5 years and the glue or whatever adhesive used has hardened.
It appears the quality of the prep work behind the repaint plays an important role too!
So now just want to hear from those that actually had it removed.
Appreciate the feedback.
Old 12-14-2012, 01:29 PM
okbarnett
okbarnett's Avatar
It shouldnt peel
Old 12-14-2012, 01:33 PM
kosmo
kosmo's Avatar
it should not peel w/ proper techique and heat gun.
Old 12-14-2012, 02:05 PM
JayRace
JayRace's Avatar
I just removed 6 year old 3M clear bra and had no issues. Gently heat with a heat gun to loosen/soften the adhesive and slowly pull at an angle. Use 3M adhesive remove to get the remaining residue off. Just takes some time but not difficult.
If you have non-factory paint under it, there is always a possibility of peeling, especially for sub-par paint work.
Old 12-14-2012, 02:10 PM
911Königin
911Königin's Avatar
I see you have become a quick change artist!
Old 12-14-2012, 03:24 PM
f4 plt
f4 plt's Avatar
I removed clear bra that was on OEM paint BUT on top of the OEM clearcoat were painted stripes and the clear protector film was removed without pulling the painted stripes. That said to be safer either leave the car in the sun for a period or carefully warm ( notice I said warm not heat) the film with a hair dryer or heat gun. That will loosen the adhesive and make the film more pliable, then pull slowly and evenly.
Old 12-14-2012, 04:48 PM
David A
David A's Avatar
I removed mine after 4 years, no problem.
Old 12-14-2012, 06:07 PM
Spokane5150
Spokane5150's Avatar
Removed mine after 4 years because it was looking like hell. I used a comercial grade heat gun and it peeled off easy.
Old 12-14-2012, 06:33 PM
PHX 911
Official Rennlist Snake Slayer
PHX 911's Avatar
I peeled mine off, and this was under it...
Old 12-14-2012, 06:44 PM
Mbiondo
Mbiondo's Avatar
Holy aft-end of a jet engine attached to a Beatle, Batman! Wait; or is that just a phallic symbol?
That's too funny.
Old 12-14-2012, 10:10 PM
DOOBEE
DOOBEE's Avatar
I peeled mine off a 2007 that I bought a few weeks ago. I ended up finding a strange flaw in the clear around one of the headlights only to realize that fender had a spot repair that wasn't visible under the intense swirls in the bra. The clear didn't lift, just revealed something unexpected.
Old 12-15-2012, 01:57 AM
aaks38
aaks38's Avatar
As someone else stated, use a heat gun along with a soapy spray to spray as you start peeling back.
Old 12-15-2012, 02:20 AM
Knight
Knight's Avatar
As I figured, it sounds like everyone has no issues taking a clear bra off OEM paint.
Challenging to get a consensus from non OEM paint. Either way, thanks for the input!
Old 12-15-2012, 12:30 PM
Marine Blue
Marine Blue's Avatar
I removed a 10yo clear bra off of OEM paint with no issues to the paint. But my fingers were nearly bloodied by the procedure and I had to spread the removal over several days. Heat is definitely helpful but only to a degree, too much heat will make it too soft and not enough will not allow the adhesive to soften up.
This particular car sat outside and the bra was exposed to the elements so it was brittle.
Newer bra's are suppose to be much easier.
Old 12-15-2012, 04:17 PM
amfp
amfp's Avatar
It may peel if the non OEM paint didn't cure, meaning, the clear bra was applied right after new paint from a body shop.
Quick Reply: Clear bra removal paint peel?
