Intermittent clutch switch related issue with 997.2 Carrera S
Old 08-15-2012, 05:09 PM
iparrott
6th Gear
iparrott's Avatar
Default Intermittent clutch switch related issue with 997.2 Carrera S
I have a very mysterious issue with my 2010 Carrera S .... almost every time on trying to start the car from cold nothing happens when turning the key and after about 1/2 second the display says 'depress clutch pedal' (which was of course depressed before turning the key). A bit off of and on, clutch pedal in and out, and it starts ... but its an annoying 5 - 10 seconds of screwing around just to get my 2 yr old car to start!
It rarely does this when warm, and does it less often when driven and left for an hour or two than it does when fully cold.
I did have the clutch switch fail completely at around 10,000 miles (currently at 18,000) but then the warning message just came on while driving and lucky I was close to the dealer so just drove straight there.
I reported this to Porsche when getting an oil change at 15,000 but they could not reproduce. As it has got progressively worse in last 3,000 miles I am taking it in again next week and leaving it overnight for them with some instructions.
Any ideas what this could be? I wonder if its a software fault or an issue with the key switch as it is so intermittent. I could not see any other forum entries with a similar issue though.
Old 08-15-2012, 05:40 PM
Marine Blue
Marine Blue's Avatar
I'm betting it is the clutch switch again. The 987 has the same clutch switch issue (probably the same part). I believe the part has been recently updated due to ongoing problems so hopefully it won't happen again.
Old 08-15-2012, 06:02 PM
PCC
PCC's Avatar
I have a 2009 997.2 S ... I have the same problem. Had the clutch switch replaced around 3,000 miles. I am now having the problem again 12k miles. Very frustrating.
Old 08-15-2012, 09:19 PM
gota911
Newbies Hospitality Director
gota911's Avatar
Porsche recently issued a Workshop Campain WC09, to replace the clutch switch.
See link to the thread posted by MJones: Workshop Campaign WC09
Old 08-15-2012, 10:09 PM
SBPORSCHE
SBPORSCHE's Avatar
Mine had same issue- dealer fixed at last service under warranty
Old 08-16-2012, 06:25 AM
KBS911
KBS911's Avatar
Happened on my 10 GT3 and recently my 12 GTS. Dealer techs are well aware of it. They are supposedly working on a new design. Never stranded me just became an annoyance. Replace it quickly before a total failure.
Old 08-18-2012, 09:33 PM
BoomC2S
BoomC2S's Avatar
Happened to me too. Same issue, but it did become worse as time went on. I was never stranded, but took it in to have it fixed. They replaced the Clutch Interlock switch at 17140 miles last October. Have not had a problem since.
Old 08-22-2012, 02:41 PM
iparrott
6th Gear
iparrott's Avatar
Thanks for all the replies and the workshop campaign details. Just got the new switch fitted at the dealer so hopefully that's the end of this issue.
Quick Reply: Intermittent clutch switch related issue with 997.2 Carrera S
