REMOVING THE INSTRUMENT CLUSTER DIY
Old 09-14-2008, 03:21 PM
Carrera Mike
Carrera Mike's Avatar
Cool REMOVING THE INSTRUMENT CLUSTER DIY
https://rennlist.com/forums/diy-997/454458-removal-of-instrument-cluster.html#post5806269
Carrera Mike
REMOVING THE INSTRUMENT CLUSTER:
1. Lower the steering wheel and pull it all the way aft.
No need to take the steering wheel off.
2. Pull the plastic former right under the cluster towards
you or straight aft. This will reveal the two torx screws
that locks the cluster inplace.
3. Remove two torx srews. I used an extra tool(magnet) so
not to drop the screws themsleves.
4. Now you can pull the cluster straight back. It is still
held by two clips in the back, so it will need a strong tug
towards you. I found the best way is to insert your fingers
under then behind the cluster and pull it towards you.
A. The harness is held by the black harness lock tab. Swing
the black tab down and the harness will push itself off the
cluster.
The following 2 users liked this post by Carrera Mike:
dak996 (04-29-2023), pinkkot (06-24-2019)
Old 09-14-2008, 03:22 PM
Carrera Mike
Cool
1. If a new instrument cluster should be installed, read out the values if possible from the instrument cluster.
2. Loosen the steering wheel adjustment, put the steering wheel in the front-most and lowest position and lock the steering wheel adjustment.
3. Unscrew the two fastening screws 1.
4. The instrument cluster is also secured in the dashboard with two retaining clips. Therefore, pull the instrument cluster abruptly forward and if necessary push instrument cluster away from dashboard from underneath.
5. Release electrical connector on instrument cluster A and unplug it.
6. Pull out instrument cluster at the sides and to the left.
Installation is the reverse.
Old 09-14-2008, 03:31 PM
Coochas
Coochas's Avatar
Mike,
Thanks for this great DIY. I've had a very small but annoying rattle from the instrument cluster for some time. Ira Porsche was even nice enough to change out the whole cluster without resolving the problem. Now that I see how easy it is to pull out, I may try to do a little insulating of my own! Nice work.
Old 09-14-2008, 04:45 PM
sharmat
sharmat's Avatar
Originally Posted by Coochas
Mike,
Nice DIY info.
There is a TSB for this problem that does not involve a new instrument cluster but rather putting in foam insulation in the right spot. I had this fix done at the dealer; however the instrument cluster went dead during the fix and they had to order a new cluster under warranty (wonder how much that goes for). So im glad i didnt mess with it.
Old 09-14-2008, 04:56 PM
Coochas
Coochas's Avatar
Originally Posted by sharmat
Nice DIY info.
Thanks,....I did tell them that I thought there was a TSB on a cluster rattle, but I'm not sure it did any good! Maybe I'll have them try again.
Old 09-14-2008, 05:09 PM
draxa
draxa's Avatar
Thanks Mike. Very helpful indeed.
One question; if I unplug the cluster and then later plug it back, will it continue working as before or does it require some factory/OEM re-set?
Old 09-14-2008, 05:49 PM
Carrera Mike
Cool
YES. It would display all data normally.
But I wouldn't insert the key while the cluster is disconnected. This could cause CEL to come on.
Old 09-14-2008, 05:50 PM
Carrera Mike
Cool
Mike,
You're welcome. My pleasure.
Old 09-15-2008, 03:06 PM
PistolPete
PistolPete's Avatar
Thank you Mike!
Related question, I've developed a haze on the backside of two of the instrument lenses. I assume this is similar to the haze on the inside of the windshield fromt he out gassing of the interior plastics.
From your photos, I see a tab on the left side of the cluster. Can this be popped out so that I can get access to wipe down the other side of the lens or is the whole cluster sealed?
Thanks.
-Pete
Old 09-15-2008, 05:08 PM
Carrera Mike
Cool
Originally Posted by PistolPete
Thank you Mike!
Thanks.
-Pete
Pete,
I have not pulled the lenses before, But I know a lot of guys specially on the 996 board have, to replace their cluster colored dials.
The tab you noticed though maybe it.
Old 09-17-2008, 06:19 PM
mass27
mass27's Avatar
Mike,
How do you remove the instrument surround as well? This is the piece that comes factory painted in the exterior color of your car if you choose option CDP.
Old 09-18-2008, 02:27 PM
Carrera Mike
Cool
Originally Posted by mass27
Mike,
Sorry Mass, I have not gone that far
Old 09-21-2008, 11:01 AM
dianic
dianic's Avatar
like the TAG sticker, looks nice against the yellow dials. Nice touch.
Old 10-16-2008, 01:30 PM
Carrera Mike
Cool
Mike,
Dave,
Have you looked in renntech.org for the TSB of dash noises/rattles? There's a bunch of them there.
Quick Reply: REMOVING THE INSTRUMENT CLUSTER DIY
