Need a little advice before buying 996tt
Alright guys I'm just about ready to finally make my dream a reality and buy a 996tt but would like some input from the experts.
I have been looking for quite a long time to find a car that meets my standards and have come across a 100% stock, 2 owner 2001 996tt arctic silver on black with complete records from day 1 and 85,000 miles on the clock.
It recently had a full engine out service for clutch, flywheel, slave, accumulator and coolant pipes. Car is extremely clean and would easily be mistaken for a car with less than half that mileage.
My main concerns are:
-Mileage
-The non Bose stereo
-The fact that it's a 2001 potentially hurting resale
What do you guys think a fair price for this car would be?
Do you think it will depreciate at a faster rate due to the mileage and the fact that it is a 2001?
-Mileage
-Mileage
-Mileage
And imo, 2001 same thing, if it were between two time capsules, some people might pay more for a later year. On a car going 100k miles, not a factor.
What is the build date of the car? There is a sticker on the driver's door with month and year. The reason I ask is because some late MY 2001 Turbos got the 996.2 chassis stiffening. So if this car is a late build there will be no extra depreciation because it is an 2001.
I do not think the lack of a Bose stereo means much.
As for the mileage 81k is not all that much. Condition and color means more. What are your usage plans for the car?
As for my plans for the car. It will be a sunny day weekend car not likely to see more than a few 1000 km per year.
Around $40k for that car. Really depends on overall appearance and location. Get a PPI done even though it just had all that work. Is it a TIP? If so it will be the lower end of the range.
Car is extremely clean and has every single document since new, including the receipt for that deposit that the original owner of the car made.
The fact that it has a full/complete service history is important. If it has been regularly maintained (spark plugs, oil & filter changes, brakes, etc.) throughout that period, in addition to the recent "engine out" work, it should be in good/great shape.
Get a PPI done anyway, including a readout of Type I & II over-revs, and you should have all you need to negotiate a deal, all other things (color & interior are what you want) being equal. If the paint and interior are in good shape, even better.
Mileage at 85K shouldn't be an issue. Whatever depreciation has already happened for the most part. Higher mileage won't take the resale value down much more either, and production year won't matter much in the long run.
$38k-$40K is about right for the price; less if there are issues with the body, paint & interior.
The recent engine-out work covered a lot of known common issues. Other items to be aware of at that mileage are: power steering check valve (reservoir), CV boots, Cam Solenoid Bracket, front lower control arms, spoiler rams, second gear pop-out, expansion tank, headlight switch, coil packs, and sometimes the fuel pump, wheel bearings and water pump.
None of those (with the exception of second gear pop-out) should interfere with making a decision to buy at the right price.
With records of only 2 previous owners and the recent full service addressing several common needs, I'd be happy with anything around $45k if you like the car. Remember that these are getting more difficult to find in great condition with up to date service and records. The clutch, slave and pipes would cost $5-10k if you take it in and a shop does it with new hoses, water pump, belt, motor mounts, trans mount, and the often associated "while it's out" parts. The services performed would give me some comfort that my future spending has been mitigated. Get a PPI from a knowledgeable, unbiased shop where you can look underneath closely. I'd offer to drop the transmission fluid and refill during the PPI to see what is on the magnetic plug. Search my posts under transmission rebuild if you want near worst case scenario in future spending.
Any car with over 100k has a limited sale appeal to the larger majority, I own cars with over 100k and it doesn't matter to me personally but I don't kid myself either. I do realize it has 85k but your close to the 100k mark. Keep looking for a lower mile car with good records unless you plan on keeping it long term= cheaper in the long run. Just another opinion from a guy with 40 years in the car game.
With 85,000 miles, I would say $35k on the price. I don't think that you will ever see any depreciation based on the mileage you are planning to put on it - these cars have stopped depreciating and will start appreciating soon ( some say that appreciation has already started).
Non-stock radio is a minor issue. Same with 2001 vs 2002 to 2004. Basically the same car (glove box is the major issue and you will never miss it due to door pockets). I think the market values the 2001 as being essentially the same car.
The real appeal to this car is the complete service history and immaculate physical condition of the car. The problem is that here in Canada there aren't nearly as many options and with the difference in our dollar plus the import costs it makes buying from the US a much more expensive option. Car is priced at 50k firm so about 38.5 USD.
In reading the other posts this sounds like a well maintained car at a good price. Given how little mileage you plan to put on it the car will probably not lose any value over time.
What color is the interior/exterior?
