996 Turbo Forum 1999-2005
996TT Dual Mass Clutch kit $1,595.00
Old 07-17-2015, 10:59 PM
Kevin
Kevin's Avatar
Default 996TT Dual Mass Clutch kit $1,595.00
Sachs Race Engineering 764 Pressure Plate, Sachs 996 GT2 clutch disk, Throw out bearing, and pressure plate bolts.
The NEW Dual Mass flywheel is available for $895.00 Pictured.
This is a great kit for those that have a tune and turbocharger upgrades to "almost" 700HP..
Guide tube is extra and in stock if needed.
For those that have higher horsepower, I will quote you the Clutchmasters reinforced pressure plate.
Old 07-24-2015, 08:54 PM
stilov
stilov's Avatar
Kevin helped me with my clutch kit. Totally pleased.
Old 07-27-2015, 10:24 PM
Smoltz
Smoltz's Avatar
Hmmm.
Old 10-11-2015, 03:29 AM
Kevin
Kevin's Avatar
Special is still available
Old 10-16-2015, 09:27 AM
BauerR
BauerR's Avatar
How does this kit compare to the Sach 2.5?
Old 10-16-2015, 09:59 AM
"02996ttx50
"02996ttx50's Avatar
long as you've got a 764 pp? good to go. but iirc?? the 2.5 allows for a lwfw, while this one needs to be setup and have the 764 pp included at ( *some? ) cost. in addition to the actual lwfw!
Old 10-16-2015, 02:51 PM
Kevin
Kevin's Avatar
Here is the Ultimate Motorwerks Light weight RS flywheel kit with a Factory 4.0 clutch disk.
https://rennlist.com/forums/996-turb...-445-00-a.html
Old 10-16-2015, 05:45 PM
BauerR
BauerR's Avatar
What power level is this good to and what does it cost? I need a clutch and the Sachs 2.5 is at the top of the list at the moment.
Old 10-16-2015, 06:54 PM
Kevin
Kevin's Avatar
The factory Sachs Motorsport rating for the 764 pressure plate is 890Nm..
The 4.0 liter kit has been run successfully on the track (road course) at 600 to 625WHP with matching torque.
If you are drag racing your car (heavy launches), I'd recommend a different clutch kit. The organic/metal sintered clutch disk should be changed to a fibertough "glass" 8 puck arrangement.
If you are over 700HP, a reinforced pressure plate is recommended.
Old 02-01-2016, 03:05 AM
Kevin
Kevin's Avatar
A few folks are looking for New Clutches..
Old 02-01-2016, 09:58 PM
Testdr
Testdr's Avatar
Installed kevins Dual mass kit and love it. Smooth installation. Clutch is super easy to use and quiet, coming from a Carbonetics multi-disc setup. Highly recommended.
Old 02-02-2016, 03:51 PM
HBdirtbag
HBdirtbag's Avatar
Kevin,
It's not long till it's going to be clutch time for me. my ultimate goals will be around 575-600 whp. How is the driveability of this one and the 4L kit. I need something close to stock and not too heavy for the spouse.
Old 02-02-2016, 09:39 PM
Kevin
Kevin's Avatar
If the wife is driving the car. Keep the dual mass.
Old 02-02-2016, 11:48 PM
CincyScott
CincyScott's Avatar
Or if you're like me and are in touch with your feminine side. I have one in my 997tt, feels stock and holds great. I have a feeling my 996tt clutch will meet it's maker with the inbound tune (gulp) from UMW.
Old 03-21-2016, 01:15 PM
Kevin
Kevin's Avatar
On topic for those that need a new clutch.
Quick Reply: 996TT Dual Mass Clutch kit $1,595.00
