Nasty intermittent clunk from under passenger footwell
My new (to me) 996tt has just developed a nasty clunk under the passenger footwell. It seems to be occurring when cornering and changing speed (particularly under load, both increasing and decreasing speed).
It doesn't feel like a suspension problem because it only occurs when power is being applied or I'm engine breaking. Has anyone come across this before?
There's also some faint chatter while just driving along. It's very quiet but definitely new...
could be sway and drop link binding or hitting something
Basic Sponsor
Definitely sounds like a trans mount. One sign of this failure is a knocking noise under hard acceleration and braking. An easy way to check if the mount is bad is to place a floor jack under the transmission mount and jack up the transmission. If you can easily jack the transmission without also jacking up the car, it's a good sign that the mount is shot. Keep in mind that even good mounts will have a certain amount of free play in the rubber. The idea here is to determine if the transmission will jack up with little to no resistance.
If you're a DIY guy you can head to our tech articles for help on installing a new trans mount:
http://www.pelicanparts.com/techarticles/996_tech.htm
-Luccia
-Luccia
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Porsche Parts | DIY Tech Articles | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
another though more remote could be a wheel bearing?
"faint chatter"?? can you eliminate it by swaying the car side to side at speed? if so, could possibly be a bearing, but this again is just a WAG. wheel bearings are pretty easily diagnosed as such. good luck tho!..
When I had a clunking noise from my SC, it only occurred on turns. In my case, it was a bad CV joint. I'd check the CV boots and see if any of them are torn and the grease gone. With the turbo being awd, I'd check those.
