996 Turbo Used Market
Been going back and forth in my head on buying a 2002/2003 996 or 2001/2002 996 Turbo. This is the cheapest price I have seen. Obviously higher mileage and not sure about the wheels? Thoughts? Also, i see it has had 4 owners. Guess it depends on how good the service records are, etc.?
http://www.cars.com/vehicledetail/de...1291/overview/
Big difference between the N/A 996 and the 996tt with respect to performance and engine reliability. There are many threads about that here; just use search to find them (Mezger engine, etc.).
Also, look for Pre-Purchase Inspection (PPI) with respect to the 996tt. That will help with "what things to look for" before buying a particular car.
You should be able to find more than a few 996tt in the $35K-$40K range with 50K-80K miles on them. They are very reliable cars if maintained properly.
Having a full set of service records is a significant advantage when buying. Look for spoiler ram replacement, coil packs, clutch accummulator, clutch slave cylinder, and perhaps clutch disc, cam solenoid bracket, coolant pipe replacement.
On the car in the ad in your post, you may also want to check for mods to the car, and be sure to get a good PPI before making the decision to buy.
The Turbo is a great car, and it is very addictive. You'll find it hard to go back to a N/A car again.
The Turbo is a great car, and it is very addictive. You'll find it hard to go back to a N/A engine car again.
This is kind of a trivial thing, but the subject car has 997 Turbo look wheels that I suspect are the $600 Chinese knock offs. I may be old fashioned, but wouldn't want to run a 3000 lb, 400 HP car on no-name $600 wheels.
OTOH, if they turn out to be genuine 997 turbo wheels, somebody paid a lot of money and it could be an indicator that they weren't stingy with the car.
For about $1K more, there is an '03 one owner car in Costa Mesa I can point you to. I haven't seen it, tho.
My suggestion is to pay more upfront for a good car with decent miles and full maintenance records. This car is fairly priced and if ppi checked out worth that price easy. Read about the discount buyers problems after purchase= there is no free lunch.
Thanks. I hear ya and agree.
Be careful of 997 wheels on a 996. They are not the same diameter, so it can be bad for the differential. The 996 uses a standard differential where the 997 has some electronic system that can compensate for the difference.
I know for a fact that some people are using them for years without a problem, but then again I know others that ruined their differential with them. In other words buyer beware.
By the way, I passed on a 996 when I was looking for mine because a car I saw had these wheels. I like the way they look, and they look more modern, but I didn't want to risk it.
Cheers
Mikey
there are NO "absolutes" to these cars if and once properly maintained. no records four owners tracked extensively/modded as far as it can be taken without internal building etc... my car currently has over 122k miles and it runs like a stung mule, everything works PERFECTLY and besides the fact that it's never gonna look "new"? i'd put it up against ANY 996 turbo anytime/place.
and its worth .. maybe xx? a fkn travesty i tell ya.....
If you are "handy" and you want to save yourself a little cash buy a house that need some fixing up. Spend the cash to get a good trouble free car. You will be much happier that way.
Great advice! I have bought many used Porsches and used cars in gerneral in my time and the ones that have always worked the best were the ones I paid a little extra for because they were low mileage and in pristine condition.
I am saying the exact same thing you are. Buy used, but buy quality used. Get it?
