Question about engine compartment cooling fan
I assure you I don't make things up.
But I have to agree it sounds nonsensical.
I wish I had not posted that bit of info until I had the source of my info at hand. I am actively looking for the reference from where I got this info.
Sorry Macster, I didn't mean to imply that you made it up. Just that wherever you heard or read it from was likely a questionable source. Would be good to track it down somehow. Lots of nonsense on the web posted by well meaning folks.
Interesting fan discussion. My 05' has the c5 fuse, however, the fan has only run once after a hot shutdown. Car has a tune and the fan never runs hot or cold. There is no faulty parts in the fan circuit that I can determine. It has been said here that some tunes affect or delete the fan function. I would like to have the fan operate normally as currently I use a floor fan to get rid of the heat after a long drive. I was suprised to hear that a tune won't affect the fan opeation.
The part that concerns me is that yours won't turn on with the engine running, whether it's cold or hot. It seems like you need to troubleshoot it especially since you have the C5 fuse installed. Maybe the fan is bad (that's easy to check with the hair dryer), maybe the fuse is bad (easy to check) or maybe the relay is bad.
As far as the tune goes, I wouldn't expect a tuner to keep the fan off. If anything, they would make it continuously run. Generally you want things cooler when it comes to getting better performance.
You definitely don't want everything cooking in there, so I would definitely check it's operation and fix it if it's broken. A fan that's stuck on won't cause any other problems, but a fan that's stuck off can cause other heat related problems.
my fan doesn't run continually. only when it's hot but usually within 2 mins of shutdown it'll go on for a few mins and if its REALLY hot, it'll go on..then off.. then go back on for another few minutes.
but it doesn't run continually. near as i can tell lol
Thanks Mr 4speed; fan tests ok. Might be the sensor tho. I'll look for it and try to jump it out. Another issue discussed here was which way the fan should blow. The blade geometry would determine that, although some were wired backwards..
It turned out that in removing the fuse to disable the spoiler, because the spoiler hydraulics were leaking and the spoiler was operating properly, this fuse also controlled the engine compartment lid circuit, and this accounted for the non-operation of the engine compartment lid.
My thinking was the techs in going after this behavior something was done with the electrical system -- maybe a temperature sensor left unplugged? -- that caused the fan to run all the time.
But it was clear from what I was given the fan operating all the time the engine was on was an intended mode of operation controlled by the fuse I mentioned earlier.
This causes the hottest air -- around the turbos and exhaust -- to exit the engine compartment area without exposing the engine compartment hardware to the heat from these components.
And opening the engine compartment lid in the belief this results in better/faster cooling of the engine compartment is ill-advised.
Leave the lid closed and let the engine compartment fan and its controlling circularity do what it is intended to do.
The engine compartment fan should blow air down.
every 911 since day one is air in from top, air out bottom.
a great solution for track/hardcore cars would be to vent the deck lid to let the air out above the bumper...should reduce the 'vacuum bubble' behind the car and reduce the airflow pushed under the car, less lift in theory..
I always thought the engine compartment fan blows air out of the compartment, not in. Heat rises and you'd think a fan blowing out would evacuate hot air thus drawing cool air from the cool road surface part of the engine compartment. Looks like all the fans on 911s do blow into the compartment though..
Macster is on the money. It does not make sense to draw up hot air from the headers/exhaust into the top of the motora s it will increase the temps in the engine bay.
I had a similar issue in that my car kept giving me an engine compartment temp message. I knew everything in the cooling system was fine and realized the fan was blowing up instead of down. I have an aftermarket fixed wing in which the wiring was not done correctly. I simply reversed the wires and never had a problem since. Also, my car was exhibiting similar symptoms to that of the OP - the fan always seemed to be running even when cold.
^beyond thermal reasons, it would be better to suck air from the bottom to top for lift/.d.f. reasons....my fan runs full-time, and should be better for it, reasoning being better airflow/cooling for all the coldside and post-intercooler plumbing....I want to wrap my pre-turbo airbox and plumbing
Thus the fan should blow down to get the heat out and away from the engine compartment.
If the fan was rewired to suck air though and then out of the engine compartment the fan would be pulling warmer (hotter) air past the very components most likely to suffer from exposure to excessive heat but past/throgh the fan as well.
If one doesn't care about the engine compartment components at least think of the fan. It would run hotter and likely suffer from a shorter service life because of this.
Besides, even with all the Turbo (and other models of cars) engine compartment fans blowing down there is a real scarcity of any reports of any engine compartment fan failures so even if the fan is working harder to blow down vs. suck up (which I'm not even sure is the case) fan failure reports don't back this up.
This it is not a concern at all that the fan blows down and I would not rewire my car's engine compartment fan to change this direction of air flow.
absolutely agree
