996 Turbo Forum 1999-2005
Question about popout
Old 07-25-2014, 11:23 AM
Markintexas45
7th Gear
Markintexas45's Avatar
Default Question about popout
Do only certain years have the second gear popout problem or is it something that can happen to any year model? I heard is was only till 02!
Old 07-25-2014, 03:29 PM
rmc1148
rmc1148's Avatar
I believe it was most prevalent in years 01-02 but have seen it in talked about in posts from all years.
Old 07-25-2014, 05:09 PM
darth g-f
darth g-f's Avatar
All years and all versions K16 and k24 turbos (X50/turboS).
Make sure you test for this as it is a bit expensive to repair. Mine was done under warranty fortunately.
Old 07-25-2014, 07:02 PM
tt4me2
tt4me2's Avatar
how would one go about testing 2nd gear popout? I can only assume it would happen more under load or heavy gas then suddenly let off something like that but just guessing here.
I'll bet there are many threads too on this so I'll start searching
Old 07-25-2014, 09:03 PM
Kevin
Kevin's Avatar
Early production '03 had the issue (08/2002)
I'd also make the recommendation to test the car on a downhill road, in second gear accelerate and then get off the gas and coast, apply throttle and coast.. It will pop out of gear with this method.
Old 07-28-2014, 02:59 PM
911 Rod
911 Rod's Avatar
Testing didn't help me.
It has popped out maybe 4 times in 5,000 km/6 months since I bought it.
Yes, coasting.
Old 07-28-2014, 09:59 PM
Ck986
Ck986's Avatar
How many miles does it take for this problem to appear? Does it come on fairly early in about 20k miles or later on at around 50k miles.
Old 07-29-2014, 12:10 AM
Turbodan
Turbodan's Avatar
I thought I had read or seen advertised in panorama a cheap fix for this? does a cheap fix exist?
Old 07-29-2014, 12:34 AM
rmc1148
rmc1148's Avatar
Do a search here and on 6spd about detent and ball bearing fix. I do not believe there is a certain mileage that can be pinpointed for pop out.
Old 07-29-2014, 12:47 AM
rmc1148
rmc1148's Avatar
Wanted to add these fixes only work on occasion and usually the trans needs to be repaired internally.
Old 07-29-2014, 01:50 AM
Vendetta NY
Vendetta NY's Avatar
Here's a start. On mobile, sorry for not linking.
http://m.6speedonline.com/forums/showthread.php?t=331758
-V
Quick Reply: Question about popout
