996 Turbo Forum 1999-2005
$200 996 Carrera Fan = $500 996 Turbo Fan
Old 07-03-2014, 06:23 PM
928drvr86.5
928drvr86.5's Avatar
Default $200 996 Carrera Fan = $500 996 Turbo Fan
The Carrera/Boxster radiator fan bolts in and works just fine and it's less than half the price of the 996 Turbo radiator fan. In my opinion it's of = or greater quality.
The 996 Carrera fan is Bosch PN 0 130 303 233
The 996 Turbo fan is Porsche PN 9966241270
Old 07-03-2014, 06:33 PM
928drvr86.5
I found this out because a vendor (I won't name) charged me for the 996 turbo part and shipped the 996 Carrera/Boxster fan by mistake. When the fans arrived I noted the ballast (lo-speed) resistor was different but concluded it was because the fan was mfg. by Bosch as opposed to the original Gate brand fans I'm replacing. I didn't realize it was the incorrect part until I got curious and checked the part number after the fans were installed (took a phone pic of the fan).
The Carrera fan bolted into the shroud just fine and the electrical plug mated with that of the turbo's harness. The fan runs just fine too, and I now have AC again when sitting still.
When I was shopping for radiator fans I noted the 996 Carrera fans looked similar to the 996 Turbo but couldn't find any information/specification to use as a reference in determining if the 996 Carrera part would fit the Turbo.
In the end I am getting a price adjustment for the difference as I'm not tearing the fans out again.
Old 07-03-2014, 06:44 PM
928drvr86.5
Just thought you guys would want to know there is no sense spending over 2X as much for a Turbo fan when the Carrera fan will work. My car lived in hot environments it's entire life and both radiator fans gave up within a week of each other. The car did not overheat whatsoever (mid 80's ) but I noticed the AC would go warm when sitting at stop lights etc. The radiator fans on the 996TT are not serviceable, nor are the Carrera fans for that matter, but I did tear one apart just to see how they are designed.
They are a stamped sheet metal case with end caps/bearings held on by tabs bent over on each end. The motor is a 4-brush/pole type motor, all but a 1/16" of what started as 5/8" brushes had been consumed on mine and the commutator was severely worn. Even if the brushes could be replaced, putting the stamped motor case back together would pose a problem unless the utmost care was used in disassembly.
Old 07-03-2014, 06:47 PM
wross996tt
wross996tt's Avatar
thanks for the info...just posting cause it seems like you were talking to yourself...LOL
Old 07-03-2014, 06:51 PM
928drvr86.5
I was, I do it all the time.
HDA (03-05-2020)
Old 07-03-2014, 07:03 PM
rmc1148
rmc1148's Avatar
At least you have someone that's interested on the other end lol. Good catch on the fan I just replaced my auxiliary fan on my A4 and now a/c is nice and cold.
Old 07-03-2014, 07:20 PM
cbracerx
cbracerx's Avatar
I love this sort of info. Thank you!
Old 07-03-2014, 07:30 PM
993GT
993GT's Avatar
great info Ben! thanks for posting.
Even though I have no cooling issues, I have been thinking about adding an additional fan to my car(GT2's from factory only have a passenger side fan, despite still having wiring for the empty driver's side)...this makes it a lot cheaper..
Old 07-03-2014, 08:53 PM
Ahmet
Ahmet's Avatar
The turbo fans have 3 speeds, the carreras are only 2 speed. I’m not sure how it’s handled layout wise, I’d be interested in seeing the pictures. Thanks for sharing either way.
Old 07-03-2014, 09:08 PM
rmc1148
rmc1148's Avatar
I was curious if there's a non obvious but important difference= hopefully not.
Old 07-03-2014, 09:43 PM
928drvr86.5
Yeah, if you are really concerned about having an "intermediate" stage, just pull the ballast resistor from the turbo fan. The 2nd tap on the resistor is what gives you the additional stage, nothing to do with the fan itself.
Old 07-11-2014, 09:37 PM
996tt cracker
996tt cracker's Avatar
+1
I'm looking for a spoiler/engine lid fan mine rumbles like a mack truck
Old 07-31-2014, 10:50 AM
billapex
6th Gear
billapex's Avatar
Originally Posted by 996tt cracker
+1
Not to hijack the original thread, but my spoiler/engine lid fan was wobbly and made a racket when I bought the car a year ago. New ones are only ~$130 at the dealer, if I recall, and take five minutes to install.
Bill
Old 07-31-2014, 11:46 AM
rmc1148
rmc1148's Avatar
Radiators are in front= fans are different and cost more.
Old 03-30-2019, 07:55 AM
Noel Cruz
Noel Cruz's Avatar
I can confirm this works, I did save the resistor for the future to replace. I live in Miami, so I will post my experiences with the summer.
Quick Reply: $200 996 Carrera Fan = $500 996 Turbo Fan
