996 Turbo Forum 1999-2005
Ohlins road and track coilovers?
Old 05-28-2014, 04:10 PM
blockhed
blockhed's Avatar
Did you have to get them revalved or just swap springs?
Old 05-28-2014, 04:17 PM
996TWINS
996TWINS's Avatar
If you are referring to my post, the answer is no.
The KW V3s have 18 rebound and 12 compression settings.
Old 05-28-2014, 04:38 PM
Tuxiemama
Tuxiemama's Avatar
Only thing with Ohlins (I have their GT3 DFV) is the spring rates... I expect to get some very nice OVERSTEER with these and the RWD set up
Front 90 Nm/mm
REAR 140 Nm/mm
http://issuu.com/ohlinsusa/docs/rt_k...570953/4608515
Old 05-28-2014, 08:11 PM
powdrhound
powdrhound's Avatar
Received 1,750 Likes on 1,022 Posts
Front 90 Nm/mm
REAR 140 Nm/mm
Yeah, those rates are super soft. That's not gonna be much fun. I'm on 193Nm/mm fronts and 210Nm/mm rears and they are a bit soft. Swapping to 245Nm/263Nm next week. I would stick to no more than a 200lb spread max front to rear on these cars unless you're building a drift car... I ran 600/800 a while back and really had to tighten up the front bar and loosen the rear to make the car reasonably balanced.
Old 05-28-2014, 08:17 PM
Tuxiemama
Tuxiemama's Avatar
Thanks, will get the car back and then look at what it feels like on the street then adjust... also have to redesign my driveway so the car doesnt scrape too much
Old 05-28-2014, 08:25 PM
powdrhound
powdrhound's Avatar
Gonna be hard to tell much difference on the street unless you are in an area where you can really push the car hard safely. Yeah, the driveway is one of the more expensive mods these cars require. Been down that road myself..
Old 05-28-2014, 08:31 PM
Tuxiemama
Tuxiemama's Avatar
Thx, was going to try 500-700 or so, but I will see what springs Ohlins can sell me at the 600-800 or higher... had one guy tell me he is running 1200/1400 and loves it
Old 05-28-2014, 08:52 PM
powdrhound
powdrhound's Avatar
Makes sense. I find 1100/1200 a bit soft for the track but good on the street. It all depends on your shocks and what they are valves for. I doubt you can go much higher on the street Ohlins. I think you'd need to go with their TTX kit.
Old 05-28-2014, 09:14 PM
Tuxiemama
Tuxiemama's Avatar
Yeah I hear ya... I was not going to do track until next year... need to get used to the new power levels and turbo lag.... plus I am from downunder and still occasionally look for the gear shift lever on the left hand side still, even though I have lived here 11 years...
funny going to change gears and you grab the door sill
Old 06-11-2014, 04:20 AM
bcrdukes
bcrdukes's Avatar
I realize this is the 996TT forum, but how do you guys like the stock Ohlins setup on your car?
I've got a 2004 996 C2 and I'm looking to get these Ohlins Road & Track coilovers for my car. My car is a daily driver but I do plan on going to the race track in a month or two with these.
Thanks!
Mike
Old 06-11-2014, 10:09 AM
Tuxiemama
Tuxiemama's Avatar
Havent got my car back yet so will advise when I do.. but there are some good youtube videos of Ohlins at The Nurburgring doing tests
Old 06-11-2014, 12:05 PM
bcrdukes
bcrdukes's Avatar
Wow, my apologies.
Someone with more technical expertise please correct me if I am wrong, but the Ohlins setup on the 996 (naturally aspirated) is nowhere near the same as the 996TT. You folks get the TTX whereas the regular 996 is just a conventional shock and a Macphereson strut.
Spring rate on the 996 (NA): Front: 60 N/mm(342 lbs/in.) Rear: 120 N/mm(686 lbs/in.)
How does this compare to you folks with the turbo Ohlins setup? After reading powdrhound's take on it, it seems like there was something completely different and I realized, "Oh, his car is a beast!" The roads here in Vancouver are nowhere near perfect. A lot of bumps, grooves, and imperfections. My suspension, I suspect, is getting tired, so I feel them all and it's getting really annoying.
Old 06-11-2014, 01:19 PM
Tuxiemama
Tuxiemama's Avatar
Originally Posted by bcrdukes
Wow, my apologies.
Only difference is spring rates on the DFV, the TTX is for GT3RS
see http://issuu.com/ohlinsusa/docs/rt_k...570953/4608515
Old 06-11-2014, 01:31 PM
bcrdukes
bcrdukes's Avatar
Thanks for that!
Old 06-14-2014, 12:20 AM
Mtrboatvr6
Mtrboatvr6's Avatar
Anyone ever get these installed? How are they if so. These sound pretty nice.
Quick Reply: Ohlins road and track coilovers?
